Lightened Flywheel or No?
Old Dec 23, 2002 | 10:35 AM
Z 2 L8ter's Avatar
Default Lightened Flywheel or No?
I am close to buying a clutch for my car and am prolly gonna go with the centerforce dual friction clutch. Does it pay to go spend the cash on a lightened flywheel or will the stock one do the job just as well. I have heard that a lightened flywheel is only usefull on dynos and that it doesn't make a big difference. What are you guys opinions on the subject? And what brand of flywheel would you recomend?
Thanks,
Jeremy
http://community.webshots.com/user/jr3334z28
Old Dec 23, 2002 | 10:40 AM
AZ28driver's Avatar
Default Re: Lightened Flywheel or No?
If you plan to drag race do NOT get a lightweight flywheel. The lower weight will cause the car to bog when you let the clutch out. Think of it this way. A heavy mass that is rotating is a lot hard to stop then a lower weight one. You won't get as much bog with the stock flywheel.
Old Dec 23, 2002 | 02:26 PM
2001CamaroGuy's Avatar
I'm going to go to an aluminum flywheel when I change my clutch but I don't drag race. As AZ28driver stated, if you drag race its not the best mod but for anything else (where the launch is not a big deal) it will help.
Old Dec 24, 2002 | 09:34 AM
Z 2 L8ter's Avatar
Thanks for the replies guys. I do drag occasionally so I will go with the stock flywheel. Can I just take it in to be turned or should I buy a new one?
Old Dec 24, 2002 | 10:10 AM
AZ28driver's Avatar
If it were me I would just buy a new one. I don't believe they are that outrageous in price.
Old Dec 25, 2002 | 01:01 PM
Boo Yeah's Avatar
I love my fidanza, i know it does not launch as good. But when racing in the street tire class it works great. You have less tendency to break the tires loose on launch. I love the way it sounds to.
Old Dec 26, 2002 | 08:38 PM
1CAMWNDR's Avatar
Or change your launch RPM (higher) and you may have to play with tire pressure at the strip.
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Dec 27, 2002 | 03:59 AM
DONAIMIAN's Avatar
try a billet steel flywheel, not as heavy as stock, not as light as aluminum.
Old Dec 27, 2002 | 02:15 PM
Chad00ws6's Avatar
i had my stock flywheel resurfaced when I did the clutch. It only cost me $35 and it holds and works fine no gripes here.
Old Dec 30, 2002 | 11:20 AM
megathumpzillaX's Avatar
would it just be silly to put a light flywheel on an a4?
Old Dec 30, 2002 | 05:43 PM
Gary Z's Avatar
The 2002 service manual says that the flywheel is not to be machined. Apparently the contact surface is slightly tapered.
Old Dec 30, 2002 | 11:20 PM
Boo Yeah's Avatar
Mega thump, did you just ask that question?? </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">would it just be silly to put a light flywheel on an a4?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Your cat jumped on the keyboard right?
You don't use flywheels on a A4 at all. You just have a Flexplate, i think that is what it is called.
Old Dec 31, 2002 | 12:51 AM
Gary Z's Avatar
The torque converter acts as a flywheel.
Old Dec 31, 2002 | 07:25 AM
Stick only's Avatar
The surface can't be tapered or the disc would never seat. I believe they say do not resurface because of the release point on the clutch and the fact that grinding the wheel moves the clutch further away from the release bearing, limiting the travel of the bearing.
As for the light flywheel, see this post:
https://ls1tech.com/ubb/cgi-bin/ulti...c;f=2;t=004178
Happy New Year all!
MN
Old Dec 31, 2002 | 09:52 AM
DOH
In my own defense I'm coming from a manual and getting ready to slap in an automatic. Probably doomed. I just was thinking minimal weight,super fast rev ups...huge stall, 4:10s, ultralight flywheel..looseness would go by so quick you would hardly notice it except for the pitiful squeel of roasting tires.
Starter needs to spin something..
thanks for the scoop guys.
Old Dec 31, 2002 | 02:28 PM
Boo Yeah's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> just was thinking minimal weight,super fast rev ups...huge stall, 4:10s, ultralight flywheel..looseness would go by so quick you would hardly notice it except for the pitiful squeel of roasting tires.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">you meant to say losers right?? Just put a stall on it, using the biggest is not always the best, you need one suited to your driving and track use and times, as well as 4.10 may not be as big of help as you think, any time you want you can race me though, i love competition. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 3, 2003 | 01:43 AM
ratio411's Avatar
Auto trannys are more responsive with a heavy flexplate.
I don't know if they make one for our cars, but they are popular with the 'old school' racers.
Dave
