how to remove shift know
Old Nov 3, 2007 | 08:07 PM
slayerized6's Avatar
Default how to remove shift know
i know this maybe the stupidest question to ask, but how do you remove the shift ****? im turning it but it doesnt feel like its going anywhere (maybe its stripped ) any and all help would be appreciated
Old Nov 3, 2007 | 08:13 PM
Ericbigmac83's Avatar
if you stripped it pulling it off then youre superhuman. check for a set screw. is this a stock ****?
Old Nov 3, 2007 | 08:17 PM
yea its a stock. i removed it before, but after i brought it in to get the clutch swapped, it wont come off
Old Nov 3, 2007 | 08:42 PM
PewterScreaminMach's Avatar
Yeah, if it's stock, you should be able to just crank it counterclockwise until it's loose. Maybe it's just on there really good.
Old Nov 3, 2007 | 08:51 PM
just gave it another shot. i must have given it 100 revolutions counter clockwise and it still feels like it never moved
Old Nov 3, 2007 | 08:59 PM
chuckyt1's Avatar
The **** probably came loose from the threaded portion. Last time I saw this I think I ended up having to trash the stock ****. Then I was able to twist the the threaded part off.
Old Nov 3, 2007 | 09:05 PM
twisting that shift **** gives me more of a work out than masturbating. i guess ill have to wait for christmas for a new ****
Old Nov 3, 2007 | 09:13 PM
chuckyt1's Avatar
I feel your pain. Lucky for me I was taking mine off to put a new **** on.
Old Nov 4, 2007 | 11:41 AM
so how do i go about removing the shift **** then. if i try to pull it off couldnt i damage the tranny/shifter?
Old Nov 4, 2007 | 03:56 PM
chuckyt1's Avatar
Try to peal the leather back from the bottom. You might be able to get it off far enough to grab the threaded part of the **** with some pliers. At least I think that's how I did it, but it has been a while...
Old Nov 4, 2007 | 03:58 PM
2_wacko's Avatar
Mine was super hard to remove just put some ***** into it.
Old Nov 5, 2007 | 09:36 AM
i finally got it out. thanks for the help guys
Old Nov 5, 2007 | 10:04 AM
What ended up being the problem?
Old Nov 5, 2007 | 10:17 AM
FordGirlGoneBad's Avatar
I'd like to know too -- I've been trying to get mine off to replace it with a custom glass one and haven't had any luck.
Old Nov 5, 2007 | 12:08 PM
98TADRIVER's Avatar
i would say the leather wrapped part was loose and that was probably what was spinning. i had the same prob, i just gave it a good GI Joe Kung Fu Grip and took the shifter ball off
Old Nov 7, 2007 | 01:57 AM
I Go To Costco's Avatar
How did you get it off? I don't know if my shifter stick is jacked up, but I can spin just the rod and the shift **** just spins with it. I also can't get the shift **** off either, it just spins around and around independent of the shift rod.
