Textralia or LS7?
Old Oct 9, 2008 | 12:19 PM
  #61
tillery's Avatar
Originally Posted by BlackScreaminMachine
The reason why there is a census is because for a long time this was one of the only clutches people could go with, just in sheer volume has enabled everyone to see how they are.
I know your kicking the idea around but seriously, get the spec and see how long it last. the price diff isnt really much at all.
I just hammered mine yesterday, it took it like a champ and BIT HARD
Why tel him to get a SPEC when your rockin a TEXTRALIA?
Old Oct 9, 2008 | 01:13 PM
  #62
Grifter's Avatar
He explains his reason in another post.
Old Oct 9, 2008 | 01:19 PM
  #63
SIC LSX's Avatar
i have almost 40 on mine and i love it. speed shifts nice and easy and the wife can still drive if if she has too My car has 413whp and had ran a 11.6 with a 1.6 60ft with it I drive my car hard!
Old Oct 9, 2008 | 02:35 PM
  #64
DarkhorSe_SS's Avatar
read your posts and it seems the tex will be the better option for "you". If you seeing more track then street and you're also upgrading the rear it should be a no-brainer.
I don't have either but I will be getting the ls7 this month for my application right now.
gl
Old Oct 9, 2008 | 07:06 PM
  #65
tillery's Avatar
Oh. Much apoligies on misreading.
Old Oct 9, 2008 | 11:02 PM
  #66
esams's Avatar
Didn't read the posts but I wanted to say that my LS7 clutch just started slipping like a **** after 4 months of "normal aggressive daily street use" with 525whp/508wtq. She's done.
Old Oct 11, 2008 | 12:23 AM
  #67
Grifter's Avatar
Ok, I just got back from the track and it became apparent that I need a clutch much more than I thought I did. My stock(LS6) clutch is heating up way too much, I lost the pedal on a couple of my runs. It has seen a hard 17K miles but it got me thinking; do I want another stock GM clutch? Just one night of racing puts an unbelievable amount of abuse on the clutch, even if I occasionally ran it I feel like it should have a clutch that's up to the task.
Old Oct 11, 2008 | 10:10 AM
  #68
timberman00's Avatar
I had the "Z" grip in the car in May. I hated it. It did have the stock pedal feel, but the chatter was the worst. I thought my mirrors were gonna fall off! It was embarrassing to be in traffic when you have to clutch dump to keep the chatter down. After 732 miles, I replaced it with the LS7. I have 850 miles on that and it's smooth as silk. It ran 12.45 at the track with a 2.0 60' on street tires.
Old Oct 11, 2008 | 11:51 AM
  #69
Grifter's Avatar
I have solid motor mounts on a H/C car so I'm used to the vibration hah. I've also driven cars with chatter and it does suck. The X Grip seems like it should be just as good with less chatter. I'm also running 15" DR's and if I ever get a rear I'm getting slicks.
Old Oct 23, 2008 | 12:16 PM
  #70
Grifter's Avatar
Another update. As of now I think I am going with a Textralia Z-Grip and Tick adjustable master, along with a new pilot bearing, slave, etc.
Thanks again for all the input and help.
Old Oct 24, 2008 | 11:59 AM
  #71
Midnight02's Avatar
Bump for a great thread. I've been fighting with some of the same decisions.
I installed a LS7 clutch about 15K miles ago and have been very, very pleased with it's performance thus far. My car puts down 440/408 NA, I'm still running a stock 10 bolt with 3.90's and I almost always run on street radials. I've always babied the car out of the hole (that will change once the 9" rear is installed), so I can't speak much to the durability after a season of 5,000 rpm launches on sticky tires. Like most of the others noted, the LS7 has the street manners of a stock clutch with much more holding power.
I recently installed a nitrous kit and for now I'm just running a 100 rwhp baby shot -- so far, the LS7 has held up to several roll races on the N2O, however I think when I upgrade the rear and add a sticky tire, I will need to upgrade to the Textralia Z grip.
Old Oct 25, 2008 | 09:19 PM
  #72
Phynix's Avatar
the chatter isn't that bad considering you run with solid motor mounts like i do, your probably use to the car shaking and rattling in different places. I have the tex twin and tripple disc in two different f bodies, I am told that they chatter more than the single, when I am at a stop and the clutch is pressed down, it does chatter quite a bit, but if I pull the trans out to neutral and release the clutch pedal, no chatter at all, not sure but might work on the single disc as well if you do decide to go the tex route
Old Oct 26, 2008 | 03:13 PM
  #73
Grifter's Avatar
As long as the chatter is normal it doesn't concern me.
Old Oct 28, 2008 | 02:58 PM
  #74
knuckles05's Avatar
I wouldn't go with the ls7 especially if you plan on doing any other mods. The ls7 can hold the power of the vettes because of the power to weight ratio so adding more weight(the vehicle) will decrease the amount of power the clutch will hold and therefore cause more stress to it. Also if you plan on taking your car to the track the ls7 will not last long at all. The tex is a nice clutch but very pricey, I would go with that or with a monster clutch they have had really good reviews and have very nice clutches at an affordable price check out their website www.monsterclutches.com and you can call SNL Performance (817-750-2000) they actually own monster clutches and ask for Eric or Steve they can get you a clutch that will meet your needs.
Old Oct 28, 2008 | 04:22 PM
  #75
Grifter's Avatar
You might want to edit that non-vendor information.
Old Oct 28, 2008 | 05:09 PM
  #76
knuckles05's Avatar
SNL Performance/Monster Clutch Co. is a vendor they joined like 2 weeks ago.
Here's their intro thread https://ls1tech.com/forums/introductions-greetings/1005235-new-vendor.html hope this helps.
Old Oct 28, 2008 | 05:50 PM
  #77
00T/AWS6's Avatar
I just got a cam installed and had the Textrailia OZ-700 Z-grip installed as well. This clutch feels smooth as stock it was quite nice which is probably one of the top reasons that I chose it. It does shake a little but I haven't heard any chatter yet. Maybe I haven't driven it enough but there have been way too many praises for the Tex and too many so so responses for the LS7 that is why I chose it. I have also read many places that they LS7 disliked being launched hard. I vote Textrailia is the way to go!!
Old Oct 28, 2008 | 08:08 PM
  #78
Grifter's Avatar
Here's their intro thread https://ls1tech.com/forums/showthread.php?t=1005235 hope this helps.
Sorry dude, my bad. Just looking out.
Old Oct 28, 2008 | 08:10 PM
  #79
Grifter's Avatar
Thanks for the response. Where did you purchase your Tex from?
Old Oct 28, 2008 | 09:40 PM
  #80
SNLPerformance's Avatar
Just wanted to jump in here and say that if you are looking into replacing the clutch in your car with something along those lines take a look at our stuff... we back it with a 12 month warranty and will be more than happy to take care of you!
Just an idea for another clutch.
Steve Addison
817-750-2000
P.S. It is my fault that you guys don't really know about us... I'm here to remedy that.
