tranny problem
Old Feb 27, 2008 | 12:07 PM
slippinsideways's Avatar
Default tranny problem
well had the chebby dealer put in a new clutch kit (ram powergrip kit), flywheel, throwout bearing, master cylinder/ slave assembly, and now i have a few problems.
first thing my clutch is not disengaging all the way. the slave is a non bleed system (lt1) with EXTERNAL slave. it has NO air in the line seeing as it comes as a pre-filled assembly, and has been gravity bled multiple times by both myself and the chebby dealer. what else could it be? are there ways to make the slave push further? or what can i do?
second problem, same clutch install, when i got it back reverse completely doesn't work if the vehicle is on. its like the lockout is keeping it from shifting over too the right. (cant not for the life of the world push it over) YET if the car is off it goes over as normal... the dealer checked out the solenoid and wiring for me and says everything is A ok... WTF else could it be? they keep trying to tell me its linkage, yet how could the linkage of gotten f-ed up while they did the clutch install? worked just fine before...
Old Feb 27, 2008 | 09:56 PM
no ideas? seriously?!?!?
Old Feb 29, 2008 | 10:43 PM
ive pulled stuff off aldata but nothing has triggerd my attention
any ideas please?
Old Feb 29, 2008 | 10:51 PM
chromeplated500's Avatar
I'm not an expert. but I know when I put my clutch in it did something similar and it came out of it after a few Good miles. as far as the reverse, to me there has to be a speed sensor lockout. hence why it works when the vehicle is off... I know there are people that have dissabled it, but I would check into that.
Old Mar 1, 2008 | 12:17 AM
madclown's Avatar
I think the Ram clutches need a spacer on the slave. Make sure the shop used the spacer. I think you have to buy it seperate from Ram. I am sure someone else with more knowledge of this will chime in.
Old Mar 1, 2008 | 05:58 PM
i was told those where only for ls1 cars...?
isnt the ls1 t56 an internal slave? cause i know mine is an external slave (lt1)
Old Mar 9, 2008 | 01:25 AM
anyone know anything
Old Apr 7, 2008 | 03:54 PM
SweetTooth's Avatar
I'm having this same problem on my LT1 after buying the RAM HD disk and using my Spec PP (Valeo) and flywheel... Did you ever solve this???
Old Apr 8, 2008 | 08:29 AM
calhoon's Avatar
A dragging clutch will cause a difficult to shift reverse condition.
Old Apr 8, 2008 | 08:41 PM
thebart455's Avatar
the ls1 t-56 will need a shim for the slave had to do mine, my reverse would not go in until i fully bled the clutch system, as far as it not fully disengaging thats because you dont have the shim in there more than likely
Old Apr 28, 2008 | 08:10 AM
95ZLT1's Avatar
Anyone else have any thoughts on this? Im having this same EXACT problem with my 95. Same clutch as well. This is drivin me crazy!
Old Jun 18, 2008 | 09:09 PM
well my tranny is done for. ill have an update when i get home from class tomorrow with all the noises and problems im having...
rebuild time!
