Confused..a4 to m6
Old Mar 20, 2008 | 07:45 AM
State69champ's Avatar
Default Confused..a4 to m6
what is the difference between a "flexplate" and a "pressure plate" I ordered a flew plate beucase i was under the inpression that it was the same thing..
That is the only thing im mission in my conversion// can someone point me in the right direction please.
Old Mar 20, 2008 | 08:51 AM
270283's Avatar
A flexplate bolts to the back of the motor when using an automatic. It goes where the flywheel does in a manual set-up. The pressure plate is what presses the clutch disc to the flywheel. Hope this helps.
Old Mar 20, 2008 | 01:18 PM
SSdreamz's Avatar
exactly what he said. when buying a clutch kit, it usually comes with the clutch pac, pressure plate and alignment tool. additionally you need a flywheel.
Old Mar 20, 2008 | 10:33 PM
your saing a NEED a ney flywheel when doing this swap??
Old Mar 20, 2008 | 10:40 PM
meatman's Avatar
Flexplate for an auto car....
Flywheel for a manual car....
Pressure plate for a manual car.....
Auto car has a flexplate which the torque convertor bolts too.
Manual car has a flywheel which the pressure plate bolts to with the clutch disc in between.
So you will need
Clutch kit-Pressure plate, clutch disc, throwout bearing, and pilot bearing
Flywheel
Old Mar 23, 2008 | 09:29 AM
the question still stands... do i HAVE to have a new flywheel when doing this swap?
Old Mar 23, 2008 | 06:00 PM
270283's Avatar
If you have a used flywheel in good shape, meaning no heat created stress cracks, use it.
Old Mar 23, 2008 | 06:16 PM
slayerized6's Avatar
its also good to get the flywheel resurfaced before you install it.
