Help me identify what year is this M6
Hi guys i need some help finding out what year is this t56 . The tag on it says
DLF 13-86 009
*61DLFU018212
There is a casting number on the drivers side it etched in that says
1S2120008
There is also a casting # on the same side that says 13-86-065-902
The trans also says use Dextron II automatic transmission fluid.
Thank You
DLF 13-86 009
*61DLFU018212
1S2120008
Thank You
This is not the case because of the part # he has. I'm not sure of the 2.97 gear set # but the 3.36 set box is a 1386-000-006. It is true they handle less torque but this is due to the ratio sets more than it is due to construction.
