shifting above 6600rpm?
Formerly 4mulaJoe
I shift right about there. There are a few things you can do. The main thing that helped for me was the mcleod m/c with the drill mod. At that point I could hit shifts at 6600, but it wasn't smooth. I switched from redline atf to some generic dexron 3 fluid and it was 1110% better. It's still not as smooth as I'd like but I hit shifts just fine.
Thanks Joe, i run GM Dexron 3 not any synthetic slippery stuff. You are shifting same as me, but im looking to rev higher especially after i increase cam size on my daily driver. 7000 is going to be target rpm, but it wont shift there now, i do have drill mod presently.
Wow they are high shift RPM's, never tried shifting over 5500 yet, as the engine is 96K old not sure of the service history I suppose I have been playing it safe. What is the rev limiter usually set at on a 2000 Trans-Am WS6?
I shift at 6900 and I haven't had a problem and I have been doing it for 2 years now. I have a Mcleod master but it isn't drilled out and I haven't changed any fluid. You shouldn't need to change anything to be able to shift that high.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The key is having properly working hydrualics. I was shifting my last solid roller at 7300+ a few times and everything went fine. I would recommend an adjustable m/c with ANY clutch you install. The '02 m/c works well with some clutches, but the Mcleod is the better piece in my opinion.
I used the Mcleod adj. m/c with no drill out mod and the Rev-lok II clutch setup.
Jason
Jason
Thanks Jason, would you say you lengthened rod over stock rod's length with adj. master? Is that the stock setup's problem? I have 2001 car, isnt that same as 2002 ZO6 setup?
My 01 is set at 6200 stock.
my car has a really hard time shifting past 6000 RPM also.....
I have a Spec stage 3 clutch, 01 (stock) slave, and have done the drill mod...
I run high temp (motol) fluid in the hydrolic system and have the GM Dexron 3 (which helped some).....
would the Mcleod adj. m/c help the trans shift better and how?
