Loose Shifter?
Old Jul 4, 2008 | 02:56 AM
SUPRSLO's Avatar
Default Loose Shifter?
I have an 02 SS and as of this morning my shifter is pretty loose while it is in Gear. It moves side to side and forward and backward more than normal. It for some reason just started this morning. I'm not the best with transmissions, so is there anything that could of came loose that i can just tighten or is my shifter wearing out. It is the Stock Hurst that comes in the car and the car has 52,xxx miles on it. Any Ideas?
Old Jul 4, 2008 | 10:51 AM
CaliboyTA's Avatar
does ur shifter rattle like a bag of change?
Old Jul 4, 2008 | 02:40 PM
SUPRSLO's Avatar
Yeah its really annoying!
Old Jul 4, 2008 | 03:41 PM
CW00BlackTA's Avatar
Check the bolts that hold the stick on and the bolts that mount the shifter to the trans.
Old Jul 5, 2008 | 01:56 AM
SUPRSLO's Avatar
could it be that the bushings are worn? and it only rattles when i'm on the throttle.
Old Jul 5, 2008 | 06:54 AM
Viper's Avatar
That could be a worn transmission mount. It's under the car, attached to the transmission and very easy to replace, even if you are not a tranny guy. If you go to www.installuniversity.com they have a writeup with pictures, it takes 10-25 minutes.
Old Jul 5, 2008 | 02:17 PM
SUPRSLO's Avatar
I Thought about my tranny mount but I really dont think its that. It feels like something in the shifter. I've done a mount on my buddy's TA and it was easy.
Old Jul 5, 2008 | 06:56 PM
Viper's Avatar
A blown tranny mount will make the shifter bounce all over.
Old Jul 6, 2008 | 09:27 PM
FatZ28's Avatar
+1 on the tranny mount
Old Jul 7, 2008 | 04:05 AM
CaliboyTA's Avatar
a blown tranny mount will make the shifter bounce, but a worn out shifter will make it sound like loose change. thats how my old hurst sounded like and it was really worn out
Old Jul 7, 2008 | 04:57 AM
95 Z28's Avatar
Check out the tranny mount and shifter bolts. Also make sure the little plastic cup that goes around the bottom point of the shifter where it goes into the tranny is still intact.
Old Jul 8, 2008 | 12:36 AM
slayer_taunu's Avatar
+1 for checking the bolts that hold the stick on. i had mine back out on me and the stick actually fell off while i was on the highway!!! seriously scarry stuff. a little loctite when putting it back on, problem solved.
but also check the shifter mount bolts themselves and the tranny mount.
