Time for a rebuild... Now what?
My T56 needs to be rebuilt and I want to take advantage of whatever I can while its apart. Should I upgrade the components to something better than stock? My clutch seems fine but should I upgrade it as well? Flywheel?
My engine is mostly stock but I would like to upgrade to a stroker (416 or 427 ...something in the 450-500hp range) in a couple of years. any suggestions?
how many miles?
if you are taking the transmission off, i would recommend replacing the clutch also.. theres no need for another heartache once you have to take the trans back off in a few months to replace the clutch
85k miles. yep, it looks like the clutch will be replaced as well. Any suggestions for 450-500 lb/ft torque?
I prefer complete over kill. heres whats in mine:
G-Force solid keys Gears 1-6
Bronze fork pads
RPM modified 1-2 shifter fork
Heavy duty steel 3-4 shift fork
30 spline mainshaft conversion - same as the Viper
26 spline Viper input shaft - bigger diameter than stock - same as the Viper
Hand fit sliders and hubs
New Compressed Carbon blocking rings
Full micropolish by Performance Metal
Cryo treated by 300 Below
All new bearings and seals
All clearances set to race specs
Assembed to RPM specifications
Bronze fork pads
