What does this means?
Old Sep 11, 2003 | 09:26 PM
LSs1Power's Avatar
Default What does this means?
Today my clutch engages early unlike before and its getting really hard to shift between gears. The tranny is fighting me. Before it was very smooth and easy going. What could this be? Please help.
Old Sep 12, 2003 | 12:46 AM
jrp's Avatar
jrp
SN95 Director
Default Re: What does this means?
does it happen at all rpms or just at WOT and is it on up shifts and down shifts.
my clutch seems like it doesnt want to disengage at WOT and from my research on here i think its the hydrolics.
Old Sep 12, 2003 | 01:41 AM
LSs1Power's Avatar
It happens everywhere. When i want to shift to 1st while im stopped. 2nd, 3rd, 2nd, 1st all speeds. Its something new. Even the engagment of the clutch changed since yesterday. The clutch became softer and the shifts became very harsh to the point its hard to shift!!
Old Sep 12, 2003 | 10:56 PM
jrp's Avatar
jrp
SN95 Director
could be issues with the master cylinder or air in the lines :dunno:
Old Sep 12, 2003 | 11:21 PM
LSs1Power's Avatar
Today it got even worse. I couldnt get the gear into Reverse and even when my foot is planted on the clutch the car seemed to want to move when its in gear. I checked the clutch fluid and it was fine. The master cylinder were replaced a month ago with the clutch. So i dont know if thats the problem. The car was running fine for a month with the new clutch and master cylinder. What could be the problem???
Old Sep 13, 2003 | 06:07 PM
P Mack's Avatar
Maybe you need an adjustable MC, but i don't know why it would change all of a sudden like that. Just try to get it fixed fast because when your clutch doesn't disengage all the way like that it's real hard on your synchros. In the mean time double clutch when you downshift, match revs, etc.
Old Sep 13, 2003 | 06:10 PM
LSs1Power's Avatar
I always match revs when i shift, but the weird thing is that it was fine for a whole month and it started doing this for no reason.
Old Nov 12, 2004 | 12:26 PM
Toonz's Avatar
Did you ever solve this problem? Mine is acting similar now.
Old Nov 23, 2004 | 02:31 AM
LSs1Power's Avatar
Yes, after setting up the Master slave more than once... We noticed that its moving a little bit which was affecting the adjustments. So i did put a red lock tite on the Master slave rod the last time i did adjust it and never looked back. Its driving fine now, but i need a stronger clutch now to hold the power and weight of my car. I might go with STAR stage 4 ceramic unsprung clutch. Mighty Mouse is running it with 800rwhp+ and 3800lbs race weight with no problems. The Mcleod is biting hard now on the streets, but it just doesnt like to be run at the track on stikcy tires with the weight and power the car is making.
