RSD at WIR Fri. Sept 9th
Rsd
hifi, Ill have my Z there if you are interested in a race. Sounds like it should be a pretty good race. I still have fully stock suspension and the stock 10 bolt with 3.42 gears. We can do it for a few bucks or just for fun I really dont care, I just like to race. Anyways, let me know if your interested, Ill look for your car.
I won't have much money with me since I'm super low on cash.....but I want to get there and make some passes and maybe make some runs for fun
Originally Posted by hllywd
HIFI,
Love to run ya, but have previous plans.
I might head down to GLD Tues night though.
I sure wish WIR had some Tues, Wed night fun run stuff like GLD.
Yeah, it would be nice if they did more around here
Shout to HIFI and HLLYWD Well once again I will not be able to make it. The GF has made plans for us to go up to Peshtigo River for the weekend. (COTTAGE) . Hey hllywood where is GLD? I am hopeing to have my LT's installed before the last RSD in OCT.
Hi Uno
Great Lakes Dragway is by Union Grove, almost to the Ill border, Bout 2 hrs for us.
They have Fun run nights almost every Tues and Wed.
Might head down there on the 13th. Cruise a little then maybe make some passes at GLD.
Todays header install went badly. One is in and needs to be removed because when I unwrapped it(wrapped to protect from scratches during install) I found it is touching the frame. The other side had a broken manifold to head bolt in a location the headers use. Went to Hartbor Freight and bought a cheap 110volt welder because with the cast iron heads you can weld a nut over a broken off bolt and spin it out well the weld keeps breaking. I am debating swapping in my spare heads. Would let me swap in my beehives and larger TB(58MM so I have to port the intake) at that time as well as go to a slightly thinner headgasket I actually have everything I need exept head bolts I am not sure if I can reuse the stockers or not. At least I have the wagon, otherwise I would have had to get the headers in and deal with the fact the broken bolt would have toasted expensive header gaskets FAST. So basically I started at 9:30am and by 7:00pm all I had accomplished was tearing the car apart. If I can get my hands on one I might try a right angle drill before tearing off the heads.
