Another Hall's deal!!!
#9321
#9323
I'll definatly need you. I don't think I'd have the new rockers by next Saturday anyways. The parts just got shipped to Harlem Sharp a day ago. By the time it gets to them, and I get them back it will probably be around the 1st of April. So, ideally if you could make it the 5th and 6th of April, that would be perfect.
I'll give ya a call sometime soon.
The weekend of the 4th and 5th would be good unless Nate has the car ready for pickup. Then that could be an issue. Although, if a miracle happens and he's got it ready this coming weekend I'll tell AutoZone to pound sand, I'm getting my car, in which case there's no issue.
#9324
#9325
Or the guy with the little foreign suv with hydraulic's that collapsed it on the front tire lol... Then came over and asked us for a jack!! That was funny.
#9327
#9328
been trying to track down an intermittent no run condition in my 92 Park Avenue. I at first was looking towards a fuel issue, i was wrong looking at that, pressure was 39 psi with vacuum on the psi regulator, and 42-4 with no vacuum. Was going to pull off the ign module when i came across these bare wires. I cleaned them with brake clean, but there was mass amounts of green fungus growing on them. My question is this. What would be the best way to go about fixing this? Should i go to scrapyard and pull a connector off another car and solder it in? Should i try to repair the wiring/ cut the wires and replace the terminals inside? I have the tool to remove the pins from the inside, but i dont know the name of them if i were to have to order them from the parts store.
#9329
You could probably depin the connector, and then heatshrink the ends of those wires (where they're damaged) with some glue filled shrink and reassemble the connector.
That, or just buy one a yard and solder it in (and glue shrink it).
#9331
#9332
What year is that off of? I have a huge box of 3800 engine harnesses and may have an ignition module connector.
#9333
HERES ONE, THE ELCAMINO WHO WOULD DO DRY PAVEMENT DOUGHNUTS AT KITTLES LOT THEN PULL INTO SUPERSHOPS AND ALL THESE GUYS WOULD JUMP OUT AND CHANGE HIS TIRES....IT WAS LIKE A CLOWN CAR.. or the guy on the crotch rocket riding the handlebars arcoss the lot hitting the landscaping and killing his bike and rolling like 5 times on the ground, that was not DIGGITY E that threw the rock it was carlos mancinia hershisher, he moved years ago....
#9335
or before i knew brad and he cut me off on 30 one night and we got back to supershops and choked him like one of those stress dolls...and i kept calling Maul his buddy tiger woods...
#9338
no just I poured **** under his car, than took a qt of mobil 1 out of my trunk and mixed it with the coolant.....
on another note just popped back on ls1tech, and on top where you can advertise a add not on the side but the pop ups is a TOYOTA ADD!!!!! FN TOYOTA add on ls1tech, SELL OUTS!!!!!!
#9340
DITTO, i think sdb said he sold it. Who knows, hey chris did you go out saturday night was anyone out? other than ricers? I know Blake was rolling, i wanted too but had issues with the better 1/2... says i was starting halls to early this year..
