Another Hall's deal!!!
#9483
Ok guys I've got a question for you. I'm buying a borla muffler with tips from a friend and I want to make it into a full cat-back exhaust. So what I need is the mandrel bent pipe that goes over the axle and the other pipe that connects to the cat. Anyone know where I can get these pipes? Anywhere here in Ft. Wayne, or will I have to find them somewhere online. Thanks for the help.
#9484
#9486
#9488
#9492
Fully loaded 1999 Blazer LT. Now we won't be scared to death when we go snowboarding, and I can go off roading at Lukes and at the park with Kenny ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
These pics are from the ad, I'm picking it up on Friday:
![](https://images.craigslist.org/3kd3pe3l3ZZZZZZZZZ93ra3ebb1d8e7f41794.jpg)
![](https://images.craigslist.org/3m33o63p9ZZZZZZZZZ93re8a127751d9314c4.jpg)
#9495
#9498
This is copy and pasted from what i read up on the hydrazine.
The EPU is designed to run on hydrazine and bleed air pressure. The EPU uses hydrazine to start but can run on bleed air if you are going fast enough. If it is running in hydrazine only mode, then you have about ten minutes, depending on how much you use the controls. The flame out pattern is designed to handle a 50 knot headwind. The AOA window is based on the 210 stores and fuel. Must folks would carry a few extra knots for the wife and kids, but not too much. Once flared and into ground effect it is hard to slow the jet down.
#9499
Thank ya. I'd kinda like to continue keeping all my bones in one piece, but we'll see.
Already been done, along with new ball joints and a rebuilt motor and trans. All I need is a TCCM and I'm ready to rock and roll.
New sig I see..... Just remember Ponies Are For Pre-Teen Girls
