Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Another Hall's deal!!!
Old 03-15-2010, 08:22 AM
  #13041
halucinator's Avatar
I always test my thermostats in a pan of boiling water before trying to install them. Sometimes the rubber around the opening will cause it to stick shut.
Old 03-15-2010, 02:48 PM
  #13042
SS1875's Avatar
[QUOTE=The Beast;13033348]
Also, has anyone had Pancea or ProStrip ceramic coat your headers?
Dropped some parts over there last Friday. Set of LTH's were lying on the floor after being coated...looked pretty good from what I could tell looking over the counter.
Old 03-15-2010, 03:28 PM
  #13043
LTwonZ's Avatar
Thanks Darren and Crystal says hello. Are you having any luck with the job search?
Old 03-16-2010, 04:07 PM
  #13044
1bad98z's Avatar
Looking to trade my Eibach pro kit (less than 5k miles on them) for Eibach drag launches or stock spring plus $150. I would prefer stock springs with less than 75k miles. Springs are off of my 98 Camaro. Let me know.
Ryan
Old 03-16-2010, 06:10 PM
  #13045
CALL911's Avatar
Don't kick Shawn in the *****, it was all Joes idea to sell you the faulty thermostat.
Old 03-16-2010, 11:34 PM
  #13046
SS1875's Avatar
Had one offer from Nate, however I didn't take it at the time, thinking I had a good shot at another. So, the search goes on and frustration builds.
Old 03-18-2010, 08:43 AM
  #13047
digitalsolo's Avatar
I keep hearing about this "Joe" guy on the radio. Oddly, they keep putting his commercials right by the ones for strip clubs? Coincidence?
Old 03-18-2010, 02:22 PM
  #13048
Slowr w/o Blowr's Avatar
Joes name is all over the radio! I never heard any strip club commercials, but did hear one about the scared and pregnant one right before his.
Congrats Joe for being FAMOUS!
lawlz!
Old 03-18-2010, 04:37 PM
  #13049
GMMillwright's Avatar
Tires are here. Wheels should be here next week. Rear is still at powdercoat, so (hopefully) the week after next.
Old 03-18-2010, 09:01 PM
  #13050
LS1TECH Sponsor
Azar's Avatar
As an aside, I'm still out job hunting...anyone hears anything, let me know crackaz.
Old 03-18-2010, 09:04 PM
  #13051
Spent an hour today troubleshooting what I wired wrong for my alternator... turns out the alternator was bad, LOL. Should of known -I- didn't do it wrong...
Old 03-18-2010, 09:08 PM
  #13052
CALL911's Avatar
Azar, "Male Jiggilo"?
Old 03-18-2010, 10:19 PM
  #13053
The Beast's Avatar
You raise a valid point. Joe is obviously the brains behind that whole operation over there, and it's no secret that Shawn lacks the mental capacity to think up such a devious plan...Hmmm... Better kick them both in the *****, just to make sure
http://fortwayne.craigslist.org/ppp/
Old 03-19-2010, 07:37 AM
  #13054
Silver UltraZ's Avatar
I don't recommend kicking Joe in the *****, "He'll see you in the streets" eventually... And for Shawn.. Does he have *****... Just wondering.
Drew get a job.
Old 03-19-2010, 12:35 PM
  #13055
Update on my 3800 dilema. After T-shooting that POS for about a week, i finally found the issue. Put this on your weird **** to look for list. Cracked bakeolite on the cam sensor allowed oil to penetrate the electrical terminals and was causing an excessive amount of resistance in the plug.
Symptoms - would run about 8 or ten minutes then the timing would get all phucked up and would die. If you tried to keep the car running it would hammer hard from preignition/ timing out of whack. DIS w/ magnavox coil assembly. (no distributor) No codes for cam sensor in the computer.
Old 03-19-2010, 12:49 PM
  #13056
LS1TECH Sponsor
Azar's Avatar
Guys,
I have tried working the corner and I had no takers. I think I wasn't showing enough moob cleavage...or maybe my shirt was too long. I don't know, but I never thought the demand for an overweight male hooker could be so low.
Old 03-19-2010, 12:52 PM
  #13057
CALL911's Avatar
^ You're probably just not working the right corners. Talk to Joe, he knows where you should be trying and is very familiar with them.
Old 03-19-2010, 01:10 PM
  #13058
That's just f'in weird. Glad to hear it's resolved though, sorry I couldn't be more help on it.
Anyone going to be out and about tonight? If all goes well I may have the FC out. Most likely... not.
Old 03-19-2010, 02:35 PM
  #13059
tunedports10's Avatar
good catch luke no can you figure out why a 2005 saturn ion 1 only gets 17 mpg
Old 03-19-2010, 08:48 PM
  #13060
switches's Avatar
I can ,its the drivers fault.
Quick Reply: Another Hall's deal!!!
