Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Another Hall's deal!!!
Old 03-19-2010, 08:53 PM
  #13061
tunedports10's Avatar
Maja says **** you
Old 03-20-2010, 04:07 AM
  #13062
Slowr w/o Blowr's Avatar
Originally Posted by tunedports10
Maja says **** you
Is she offering it out now? Must be looking for a tough guy since her man won't watch Twilight with her.
Old 03-20-2010, 04:15 AM
  #13063
good catch luke no can you figure out why a 2005 saturn ion 1 only gets 17 mpg
Fill the gas tank up clear full for me and let me drive it for a week. I'll let you know what the problem is then. If i can't figure it out, you may have to let me drive it for another week after you fill up the tank.
Seriously though, have you checked the inlet and outlet temp of the Cat? Plugs good? Possible to have a bad fuel injector? We could rig up a wideband in it and put one of my MIL eliminators on the downstream 02 sensor. Let me know if you need a hand. I remember you bitching about it last year.
Old 03-20-2010, 02:16 PM
  #13064
digitalsolo's Avatar
Jared, just LS1 swap it. We can get a solid 32-33 mpg with some 3.07 gears out back.
Old 03-20-2010, 03:24 PM
  #13065
switches's Avatar
Maja says **** you
Promise
Old 03-20-2010, 10:41 PM
  #13066
Better watch out with her, I'm pretty sure last time I saw her at Pierre's, she threatened to shank me.
Old 03-20-2010, 10:47 PM
  #13067
Lol she's a handful trying to keep her from shanking people and what not. Switches I believe the **** you was more of a suggestion of what you could do to yourself. Much like everyones favorite "go **** yourself"
Old 03-21-2010, 08:08 AM
  #13068
switches's Avatar
I know,just messin around. Tell her I said HI
Old 03-22-2010, 02:59 PM
  #13069
LS1TECH Sponsor
Azar's Avatar
Hey, if anyone knows a car for sale around 2k or under...let me know.
My buddies truck popped a headgasket and it's not worth it to repair it. He's looking to replace it.
Old 03-22-2010, 03:42 PM
  #13070
Buy my Buick Park Avenue. Pretty sure i've got all the problems worked out now. Been driving it for about a month now.
1500 dollars.
Old 03-22-2010, 03:43 PM
  #13071
double post..... Weird, i only clicked the button once.
Old 03-22-2010, 03:45 PM
  #13072
http://www.fortwaynemuscle.net/forum...55&postcount=1
Old 03-25-2010, 08:39 AM
  #13073
Brent@LPE's Avatar
Drew Im selling the sten for 2 k....Let me know
Old 03-25-2010, 02:29 PM
  #13074
KDog- The new mustang just got chassis dynoed. From the factory its rated at 412crank horse. But it is putting down 395rwhp bone stock. Sounds pretty underrated to me.
This is an excerpt from an article that George Klass wrote- "he compression ratio is 11.25:1. With 4-cams it's easy to do and not have detonation. The problem is that most mod motor racers set their cars up as if it was a pushrod (single cam) motor. Our total valve lift is so low that you would laugh about it, it's less than most street cams. The new 2011 Mustang 5.0L 4-cam engine has computer controlled camshaft timing. This means that you can set the engine up one way for the launch (when the boost is only 40 psi) and change the cam timing as the boost comes on. And the intake cams and the exhaust cams can be controlled INDEPENDENTLY from each other with the Motec computer.
We have these engines in our shop, thanks to Ford Racing. Right now our 4-cam 4.6L is making about 9 horsepower per cubic inch on gasoline. Wait until we turn the Coyote loose. The potential from this engine is unbelievable. When you see this engine disassembled, you would swear that it's out of a Formula 1 racecar, and it's a production piece. The computer controlled cam timing in the 2011 Mustang is set so conservative that the engine can make about 410 hp and still get almost 30 mpg, and be 100% emissions legal. The headers are full tube race headers, not those crappy shortys. The OEM throttle body is 80mm. I would not be surprised to see a sharp guy with an SCT tuner get 500+ hp out of this engine just be reflashing the OEM computer, with NO mods to the engine.
http://blogs.insideline.com/straight...ang-gt-50.html
Old 03-25-2010, 04:00 PM
  #13075
9 HP/ci? That's 2500+ HP. I'm going to go ahead and say there isn't much to do with factory parts on that engine.
The new 5.0L definitely brings a lot to the table. Until GM starts putting direct injection and turbos on the LS series motors...
Old 03-25-2010, 09:59 PM
  #13076
Anybody wanna build an LS1/RX7? I'll have a mounting kit available for cheap soon, changing to C6 Corvette pedestal style mounts.
Old 03-26-2010, 08:16 AM
  #13077
CALL911's Avatar
^ I would, although its on the extemly long list of things that are probably not ever going to happen.
RX-7 LS1 builds are a great setup. Light, fairly inexpensive car, all on a fairly inexpensive build, and very capable. Oh if I only had a pile of money... well a pile I wasn't already going to dump on a house.
Old 03-26-2010, 03:50 PM
  #13078
Transamthunder's Avatar
So Liberty Dinner is the new hang out what happened to Halls? Maybe I havent read back far enough, but there is over 600 pages of reading here. Looking forward to seeing the Rx7 hopefully this year that oyu been slavin over Blake.
Old 03-26-2010, 04:14 PM
  #13079
Oh found something kinda funny bout this test. Ford enthusiests were screamin bring on a Shelby against an SS. Come on really? I think once the Z28 gets the LSA it will be a good match up. Heck throw on a Maggie and your gonnabe pretty close powerwise right witha regualer SS and loads of cash saved over the Shelby.
http://www.youtube.com/watch?v=_C9za...eature=related
Old 03-26-2010, 09:32 PM
  #13080
Oh, it'll be out, I've been driving it the past week or so.
Hall's kicked us out, because they're idiots. Liberty invited us down there because they're awesome. Food is much better as well.
Quick Reply: Another Hall's deal!!!
