Another Hall's deal!!!
#1624
I can see it now:
Next question, for $200, Who was the first person to IS THAT A MUSTANG... hold on ::chases down and does work on the stang::
OK where were we, ah yes, who was the first person to.....
#1634
You also got gears and suspension, but my car being a Formula probably weighs a few hundred pounds less than you as well (Formula being the lightest of the F-body's and Trans Am being the heaviest). FWIW, when I had mine dyno'd it was was in the Appalation mountains (3,000+ ft above sea level), also on a hot day like when yours was on the dyno. I have a feeling on the same dyno on the same day, we'd probably throw up extremly close numbers. And when we do run them (cause we both know its only a matter of time ), the outcome will be close no matter who wins.
#1636
Well I took the new car around the block today. Still have a lot of stupid stuff to do (bleed hydraulics and cooling a little better, clean up the wiring and finish the nitrous stuff, and it should be ready. If I'm not lazy this week it'll be out next weekend for some shakedowns.
My only concern right now is I have some binding in the rear somewhere. It's got an IRS, so I'm hoping I've got something seated funny from when I replaced the rear hub/bearing assembly. It's always something...
#1637
Scott, just got back from vacation today. Did Nate or anyone find anything with your fuel pump situation after pulling the pump module? I wish I had more time to spend on it before I left for vacation. It would have been interesting to have seen the amp waveform on my labscope as the pressure was falling off. It might have told us whether it was a mechanical (pump motor) or hydraulic (cavitation) problem.
32TPIBOWTIE, a.k.a. Mike @ Preferred
#1638
#1639
The wife and i had a great time at Bodigans and cruising around town with you all. Looking forward to next time. For sure i will be out looking to make some runs with a few of you. Nate you and i are gonna have a few runs. And anybody else who wants to beat up a rustang look me up.
Luke
Luke
#1640
Luke
Luke
