It lives... and all Hell followed with it...
Engine/Induction:
-Fast Toys 104mm lid. (Not on in the video still on backorder)
-F.A.S.T. 90mm Intake Manifold GFI ported.
-PTM 90mm Throttle Body ported and polished (by us)
-454ci LSX Shortblock. Balanced, blue printed and assembled. GM
LSX block, Callies Compstar 4340 4.125" crankshaft, Callies
6.125" H beam rods w/ ARP 2000 7/16" bolts, Wiseco 4.187"
custom forged nitrous pistons, Childs & Albert Fire Power rings
.043" .043" 3mm (for reduced friction & high heat applications),
Clevite MS 2199 H main brgs, Clevite CB663 H rod brgs, Dura
Bond CH-23 cam brgs, ARP main studs
-Cam Motion custom LSX camshaft (257/266 .646/.646 114 +4)
-Roll master double roller timing set w/ torington bearing &
nitrided gears.
-Melling 10295 Oil Pump ported
-Comp cams lifters 850-16
-ARP Pro series 12pt head stud kit
-ATI Super Damper crank balancer pulley
-Cometic MLS head gaskets for LSX block
-TEA TFS 245 heads milled to 68cc for 11.8:1 compression w/custom length TFS pushrods
-Harland Sharp 1.7 roller rockers.
-Mototron 60lbs/hr injectors
-Katech billet tensioner
-American Racing Headers 2" primary 3.5" collector with 4" y-pipe
-Mufflex 4" catback with Magnaflow muffler.
-Comp Cams Black vacuum canister (for brake booster vacuum)
-RevXtreme Catch can
-Speed Inc Polished billet valve cover breather
-Meziere true billet flexplate
-Hypertech 160 degree T-stat
-NGK TR6 Spark plugs
-Taylor ThunderVolt50 10.4mm plug wires
-Optima Red Top 75/25 battery
Thing's gonna be an absolute beast on the spray... and without it heheh
Personally though I would not mind getting a facsimile of the CME back as well! 6LE's 3" CME tips have been calling our name....
