My ls1 mustang
Some of you have seen my build thread on here. Its finally on the road and has about 500 miles on her. I took it to get tuned last week but i need bigger injectors. It running out of fuel at 5k rpms. Im getting a set of 42lbers. Any guess' as to what I'll be putting down after the injector swap?
My current numbers on a dynapack are 313hp/320tq to the wheels. Thats through an auto trans 4.10 gears and a 3200 stall so these numbers are low when comparing my setup to a manual with lower gears. Overall im happy since the car is so light. But im not happy enough. As the wife said to me today "youre finished but i know youre never really going to be finished with this car" LOL Shes right, I already have a new intake/throttle body and head swap getting planned.
Finally got some decent pics. The wife is learning to use her D3000 and I just did a little bit of editing. Neither of us are good a picture taking and she offset some pics on accident. But this is about the car so whatever.
Heres a list of mods for anyone wondering:
LS1
228r cam
PAC 1518 springs
Ported oil pump
chromoly pushrods
double roller timing chain
4L60E - built to hold 500hp
Trans go shift kit
upgraded clutch paks
servos
other stuff i cant remember lol
Yank 3200 stal
Lokar shifter
New Era CAI
SN95 brake booster/master cylinder
Proportioning valve delete
Wilwood brake adjuster
Stainless Steel brakelines
Stainless Steel brake hoses
03 Cobra twin piston brakes/13" rotors
SN95 spindles
SN95 disc brake rear end
4.10 gears
New rebuilt Trac Lok with 03 cobra carbon fiber clutch packs
Moser 5 lug fox length axle shafts
New emergency brake cables
Modified e brake handle to accept new brake setup
Maximum Motor Sport rear lower control arms
cheapo rear springs
QA1 adjustabke rear shocks
AJE K member
AJE front lower control arms
Custom made crossmember
Lakewood 70/30 front shocks
UPR coilover kit
Maximum Motorsport caster/camber plates
Unisteer manual steering rack
Steeda balljoints
Flaming River low profile stering shaft
Kooks custom long tube 1 3/4" headers
custom ehaust, x pipe, with magnaflow cat back and exhaust cutouts
Rear battery relocation
Glenns performance fuel tank cover color matched and chrome fuel tank straps
Walbro 233lph fuel pump
Fr500 18x9 front rims 18x10 rear rims
Auto Meter Phantom II gauges
MC Machine custom gauge panel
Edit:
Almost forgot the subframe connectors and welded in torque box reinforcements, and DHM electric cutouts that i just ordered.
Anyways let me know what you think.
Anyways, yes I would do a few things differently lol. I would have bought a trashed transmission since I ended up getting mine rebuilt anyways. Maybe used that saving for a set of 243 heads. I also would have bought a 31 spline diff and axle shafts instead of staying with the stock 28. Not much I would do diffrerent but im sure Ill think of a few more things later.
