normal?
normal?
gas pedal all the way down....still a decent size gap(at least to me) between the body n stop...noticed the cable was a little loose....is this normal??? :headscratch:
this may help:
this may help:
1 Post
No,that is not normal.You have a problem somewhere.Take the cable off the TB and see if it goes back all the way to the bump stop. If it don't then you need to clean the TB if it does you have a cable problem.
this is with the pedal pushed all the way down:
this is with me pushing it to the stop(slight difference):
im no expert but that doesnt seem normal to me....
there are little black clips that you have to pry the top off of and then adjust the cable itself by pushing in or out then pushing the top back on the cable to lock it. just look at your cables and follow them till you see these black square things in your throttle body. i just stuck a exhaust manifold on my gas pedal then went under the hood and adjusted until it WOT.
top of what?
https://ls1tech.com/forums/generatio...-throttle.html
pull the top off the one that goes to the throttle body and adjust. its not hard there are lots of descriptions if mine isnt good enough. use the sarch
