NKGs or AC delco Pro
so the other day i was getting a misfire code and i thought it was because of a plug and it was... turns out the previous owner did not tighten down the last two plugs and the number 7 cylinder was litterally hand tight, and while i was doing that i figured i would replace all the plugs. i replaced them with AC delco Professional series and gapped them to specs (.060) and it just seems like my car is running different, not sure if its a loss of power or what, can changing the plugs make that much of a difference, which is the better plug? the previous ones were NKG V's
Go find a mustang...I'll let you put two and two together.
If the weather changes dramatically, that could be it as well, my car seemed to be runnin great last night 30 degree weather, but today it felt slow in the 50 degree weather.
most likely there isn't anything wrong. Is the ses light still on? if not then don't worry about it, or get some headers if you don't already.
