help please
LOLHonestly some do some don't. My 98 LS1 never used a drop til mods. Now a little bit prolly through PCV.
My 5.3 (LM7) has used the same 1 qt. at 3K the whole time I have had it now at 185k.
JUST CHECK IT NOW AND THEN!!!!!!!!!!!!!
Yes, OP, you are burning oil. But not necessarily at an alarming level, though. Just keep an eye on it.
I do 5000. There is no chance for harm. Over in Europe they run up to 10,000 between oil changes.
there is NO reason to change every 3K miles these days when using top quality oil.
MAYBE if you run autoX or road races every weekend.
but for a typically driven...even occasional tracked..car you are fine going higher.
alot of companies are even extending the interval to 7500 or 10K miles.
changing M1 or similar full syn oil every 3K miles is nothing more than a waste of money. the oil companies are still reaping the benefits of mis-information.
if you're gonna do ANYTHING...change the oil filter every 2500 and the oil every 5000.
but definatly make sure to keep the oil topped off. running a qt low will increase the wear...in effect decrease the life...of the 4.5qts that are left.
just to see where you are level wise.
your car could probably use an oil change anyways. like everyone else has said Ls1s use a little oil, it just happens.
