Tb help
Old Dec 16, 2008 | 07:29 PM
therealcreeper's Avatar
what year is your car? don't the 98's and 99's have a different tb cam?
and i bought a ported tb that had been drilled out for a bigger cam and had almost the same problem, but not as extreme. i put in my stock blade and that helped a lot. then i adjusted the blade to make sure it was even on all sides and swapped back in my stock sensors(came with new ones) and that fixed it all.
Old Dec 16, 2008 | 07:59 PM
wsick's Avatar
Originally Posted by 99345hp
Its the holes in the throttle body. Did you try plugging them yet?
no i havent tried plugging them, mayb those are letting too much air in? but doesnt the stock tb have holes in in too?
car is a 98 are far as cam difference not sure.....
Old Dec 16, 2008 | 08:03 PM
i'm pretty sure the 98+99 tb cam is a different size than 00+. i shall search.
Old Dec 16, 2008 | 08:09 PM
https://ls1tech.com/forums/generatio...-question.html
4th post down
Originally Posted by BarneyMobile
I had to have my TB cable bracket modded to slide back about a half inch so I could run a BBK TB that had a 98-99 style TB cam. I want to go back to the 00'+ style cam. My gas pedal is way too sensitive especially with a 6spd car.
i copied it because i know i'm too lazy to click links when i read threads
Old Dec 17, 2008 | 09:10 PM
99345hp's Avatar
I think that is your problem, and I would try plugging them. I will be easy and cheap to try.
Old Dec 17, 2008 | 09:43 PM
406malibu's Avatar
uh... duh??? stock only has one hole, but some people drill them out to make them bigger or add another if they have a huge cam, so it idles better. its a cheap fix when you dont have a good tune.
