Tb help
Old Dec 9, 2008 | 11:07 PM
wsick's Avatar
Default Tb help
hey guys a buddy of mine gave me his BBK 80mm TB nothing special, came off an 02 t/a had cam n20 tune and such. so i tried putting the tb on once i started the car the rpm's stayed around 2k and dropped slightly. the car sounded like it was camming, if i gave it some gas the rpm's would rise and take a while for them to go back to 2-1500k rpm's. is there some sort of adjustment i can make? can anyone help me out with this
here are a couple camera phone pics of the tb
http://s172.photobucket.com/albums/w...t=IMAG0004.jpg
http://s172.photobucket.com/albums/w...t=IMAG0005.jpg
Old Dec 10, 2008 | 09:48 PM
wsick's Avatar
anyone??
Old Dec 10, 2008 | 09:52 PM
jsteele90's Avatar
did he give you the spacer?
Old Dec 10, 2008 | 09:53 PM
bobbyd's Avatar
loosen up the wire that goes to your tb and adjust it to the right position.
or insall it and make sure that the tb isnt open make sure the knife is fully closed if its not then do what i said and adjust the wire.
ttranssam's Avatar
??? i put a ls6 intake on a buddys car n it did the same thing but like 1500 max...where in chicago u at
Old Dec 10, 2008 | 10:47 PM
wsick's Avatar
yeah i have the spacer
are you talking about the throttle cable? how would i go about adjusting that?
by O'HARE
Old Dec 11, 2008 | 12:30 PM
bobbyd's Avatar
by O'HARE
Yup there you go for some reason i couldnt think of the name but yea its the throttle cable.
follow the one that is connected to your TB and there should be a little clip that you can click on and adjust the wire.
its real easy
Old Dec 11, 2008 | 09:49 PM
wsick's Avatar
ok so it has nothing to do with the two holes that are there? all i need to do is adjust it? why would it sound like its camming?
Old Dec 12, 2008 | 07:17 PM
wsick's Avatar
bump.
Old Dec 13, 2008 | 08:53 PM
wsick's Avatar
anyone else???
Old Dec 13, 2008 | 09:27 PM
99345hp's Avatar
if there are two holes drilled into the tb, then that might be your problem. Even with the throttle blade closed all the way, those holes might let in too much air.
Old Dec 13, 2008 | 09:28 PM
jsteele90's Avatar
my bbk throttle body had no holes drilled in it. weird
Old Dec 14, 2008 | 11:37 AM
wsick's Avatar
hmm anythingi can do?
Old Dec 15, 2008 | 07:44 PM
wsick's Avatar
and it worked just fine?
Old Dec 15, 2008 | 08:10 PM
samson_420's Avatar
I think it might have been drilled for a cam.
Old Dec 15, 2008 | 08:51 PM
99345hp's Avatar
maybe you can buy a new throttle blade from bbk? Pull the throttle shaft out and have someone weld up the holes? You could use a small nut and bolt and put through the holes, but that is going to dissrupt air flow. If it only has the shaft on one side, put the nuts on that side. Then countersink a screw into the other side. I would do this just to check if that is the problem.
Old Dec 16, 2008 | 12:46 AM
-98-Z28-Darkness-'s Avatar
if the blade closes right when installed in the car and everything...
maybe its one of the sensors on the tb that may be doing it?
see if they can be swapped out and use the original ones if you haven't yet.
make sure there it a good seal all around try to use it without the spacer if that solves the problem then your cable is on too tight and its like if your pushing on the gas.
Old Dec 16, 2008 | 12:48 AM
the_merv's Avatar
Something with the IAC Motor possibly..
Old Dec 16, 2008 | 08:59 AM
wsick's Avatar
but my stock tb works just fine........
Old Dec 16, 2008 | 07:17 PM
99345hp's Avatar
Its the holes in the throttle body. Did you try plugging them yet?
