ls1 problem. help
Old Mar 4, 2009 | 12:20 PM
ericburt's Avatar
Default ls1 problem. help
at noon i go to start my 99 z28 and it started really weak. The rpm's were hanging low and was about to stall out. I let it warm up like usual and then as i started to drive it it was bogging real bad and there was no power. I gunneed it in 2nd and it was like i was giving regular gas. Every gear was hesitating and bogging real bad. help anyone?
Old Mar 4, 2009 | 12:29 PM
ssick1's Avatar
hmmm? is ur throttle body clean?
Old Mar 4, 2009 | 12:35 PM
EVIL z28's Avatar
How many miles are on it?
Old Mar 4, 2009 | 12:41 PM
ericburt's Avatar
Old Mar 4, 2009 | 01:24 PM
2001NBMZ28's Avatar
Starting really weak/weird idle points to low battery voltage or terminal connections. I'd eliminate the battery as the problem first. Since you have a '99 have to ask if the gauges are sweeping or trip odometer is resetting on startup? - another indication of low voltage.
Old Mar 4, 2009 | 03:34 PM
ericburt's Avatar
that happened in november every start, then i cleaned the terminals and it was fine ever since.
Old Mar 5, 2009 | 05:11 PM
EVIL z28's Avatar
Check the battery voltage. Check your air filter to see if its plugged. Wouldn't be a bad idea to change the fuel filter if you've never done that.
Old Mar 9, 2009 | 10:15 AM
4DSPNKR's Avatar
Default fuel pressure
Check you're fuel pressure. If its low it might be the fuel filter or fuel pump. I had this problem and I needed to change the fuel pump at 88,000 miles. So if u have 128,000 and haven't changed th pump, there is a good chance it might be that.
Old Mar 9, 2009 | 10:23 AM
PewterScreaminMach's Avatar
I'd start with your fuel filter. Then probably the pump.
Old Mar 19, 2009 | 11:51 PM
99Hawk6spd's Avatar
Was this ever resolved? I'm seeing a very similar problem.
