piston slap?
Old Mar 7, 2009 | 08:30 AM
30th6's Avatar
Default piston slap?
im looking at a 99 ss but he says it has piston slap when its cold.is this normal for a ls1? i know its norm for a lt1 but ive never heard anything on ls1.thanks, joe
Old Mar 7, 2009 | 08:37 AM
Adam2001WS6's Avatar
Ugh, my car does this when it's cold. It sounds nasty, but I don't know how to get rid of it... by the way, it's an LS1. From the reading I've done on it, it's a very common issue among these cars.
Old Mar 7, 2009 | 08:53 AM
KENS_SS_4's Avatar
Yes it is very common for a noise at cold start up to be called piston slap.
Old Mar 7, 2009 | 08:56 AM
30th6's Avatar
thanks,sorry adam (LS1) is that better
Old Mar 7, 2009 | 09:55 AM
iowackers's Avatar
It is unfortunately common for LS1 engines to have piston slap on cold startup. My 2000 GMC truck has done this since new. It now has 80,000 on it and it sounds the same, no worse.
Old Mar 7, 2009 | 02:28 PM
udienow's Avatar
common "problem" or whatever you want to call it... Wouldn't worry about it unless it's like really loud or something. My car had only 39k when I bought it and it did/does this.
Old Mar 7, 2009 | 02:30 PM
NeedaV8foundation's Avatar
gotta love the POS 98's.... i was reading that when GM revised the ls1 in 99 they went through a series of cost cuts, causing piston slap. I have never had it, however i have a buddy with a 2000 camaro and his has it.
Old Mar 7, 2009 | 03:47 PM
waldershrek's Avatar
Have you actually hear this car run? I wouldn't buy until you do. It could be normal but it could be a headache waiting to happen
Old Mar 7, 2009 | 04:57 PM
linebacker50's Avatar
my 01 T/A makes that loud noise when its cold. it sounds somewhat like a diesel. but when it warms up a little bit, the noise goes away. glad someone did a post about it cuz i've been gettin worried about that noise
Old Mar 7, 2009 | 09:24 PM
No no no... haha! I meant "by the way, MY CAR IS AN LS1"
Old Mar 7, 2009 | 09:29 PM
schmidtycamaro's Avatar
I had it. Yes "had". I seafoamed my car today and it is magically gone. Don't know why or how, but it is.
But I wouldn't worry about it as long as it goes away after being warmed up. Very, very common.
Old Mar 9, 2009 | 05:04 PM
Lucky! I seafoamed mine and it didn't do anything for the "slap." Course, that was when it was warm outside.
Old Mar 9, 2009 | 05:56 PM
ULTIMATEORANGESS's Avatar
both my cars have it. im not concerned.
Old Mar 9, 2009 | 06:13 PM
SOMbitch's Avatar
The 98's usually have no no PS.... It is most common in the 01-02's. My 98 T/A has none but my 99 z-71 has plenty but now has 185k and runs like the day I bought it with 84K in 02
Old Mar 10, 2009 | 09:32 AM
hj99Z's Avatar
Ive got it, I'm not worried. Car still makes 347whp at 150,000 miles
Old Mar 10, 2009 | 09:38 AM
jimmyblue's Avatar
Moderator
My '02 also clatters when cold, though the noise
is a lot less noticeable now that it has a cam and
long tubes / ORY. Problem solved.
There were some motors in earlier production that
were overbored on cylinder #1, and the later years
went to tighter bore tolerances and coated pistons
to help it, but if your #1 plug doesn't foul out first
then you have no actual problem, other than
sounding like the UPS truck for the first 5 minutes.
Old Mar 10, 2009 | 11:11 AM
qwk93ta's Avatar
Mine has it when it's cold out, lasts for less then a minute.
Old Mar 10, 2009 | 01:02 PM
MonmouthCtyLS7's Avatar
Have it here also, very common problem.
Old Mar 11, 2009 | 07:41 PM
30th6's Avatar
Thanks now i feel better, what do yall think about thunders 227/228 cam and a 100 shot with 132000 and the mods in my sig?
Old Mar 12, 2009 | 06:41 PM
Pitman99505's Avatar
I have had the same prob. Thanks for the confirmation, I was starting to worry.
