noob straight pipes question
I know this is probably a dumb question and yes I have looked at the thread telling me all about the straight pipe setup, but I didn't see this come up anywhere. Now when i hear "straight pipes" I tend to think pipes strait back from the headers without much bending and they never connect together like with an X or H pipe for example. Do you have to have a connecting piece when you do this? I have personally never seen this setup and wonder why not. I know ground clearance is probably the reason why, but I just want to know for sure.
when i had turn downs coming off my headers it was super loud and made everything in the car shake. i have just a ypipe on there now and its not bad. id imagine if u had 2-3 feet of pipe coming off ur header its not going to be that bad, but it will have to be bent for best fitment. and straight pipes means straight through, no cats no muffs no res
Thanks for the info. What is the scavaging effect?
scavaging is when the pulses in the exhaust actually help pull the exhaust out of the cylinder. Can I ask why you would want strait pipes? The sounds like ***. If you get a high quality muffler if will sounds 1000x better and will have little to no restriction.
I don't really want them, just doing a little research so I get an idea of what I want to do in the future. I don't even have an ls1 yet, I'll start looking seriously for a camaro or trans am when summer gets here.
u couldnt have strait pipes for the simple fact that as soon as ur rear end moved down after say a hill or bump it would hit ur exhaust. u have to have a bend or stop it before the axle
TSP x pipe true duals for the win. I want them, but will have to fab up other stuff....not in the budget at this time. But scavenging is a plus...plus, sound and less cabin noise also. If you don't want any exhaust, just turn downs off the headers...thats it. But what you said about less bends is less restriction is true...but any quality exhaust/muffler wont be too restrictive.
Check out this link. I have this on my car and it pretty much sounds like straight pipes but 100x better. It doesnt "Cackle" when you decelerate like straight pipes do (you know how they tend to sound like someone is shooting at you) this is more smooth but still loud as hell. My personal opinion you want a few bends in your exhaust to help with backpressure. It runs like crap if you dont have enough. This exhaust system has just the right amount of backpressure, not to much but just enough.....Check it out.
http://www.texas-speed.com/shop/item...d=196&catid=56
