Weiand vs LS6 intakes on LS1
weiand is a cast metal material while the ls6 is a plastic composite. weiand willl have issues with heatsoak if you run your car hard, but on a more postive note, your able to port match the intake to your intake runners
I've got the non polished version... Car does run hotter if it sets in traffic for extended periods of time, although I've never seen the temp guage past 210. If your planning on running nitrous this is a good intake, and as mentioned above it can be ported.
Only reason to go with the weiland over an LS6 is if you are running nitrous or boost. Besides that the dyno numbers are just about identical. Check out the search tab this question has been asked and discussed alot around here.
