headers
Old Nov 9, 2003 | 05:58 PM
PewterNHRA2001's Avatar
Default headers
whats the difference between short and long tube headers??
Old Nov 9, 2003 | 06:16 PM
ALPINE's Avatar
The length of the tube off the block before the collector. Generally, longer = better flow = more HP. Laters.
Old Nov 9, 2003 | 06:36 PM
Classic's Avatar
shorties = pointless
long tubes = power
Its pretty much that simple.
Old Nov 9, 2003 | 07:08 PM
jrp's Avatar
jrp
SN95 Director
long tubes = power
werd.
and these are long tubes (hooker)
and these are shorties (jba)
and these are midlengths (macs)
if you plan to do any substantial mods (i.e heads/cam) then long tubes are the only way to go. there are some guys that for emissions reasons go with shortiest but to me its still a waste of money.
Old Nov 9, 2003 | 07:44 PM
what lenght are the headers on a stock 2001 trans am??
also what would be a good upgrade to go with??, i dont want to spend a lot of money either
Old Nov 9, 2003 | 07:59 PM
jrp's Avatar
jrp
SN95 Director
stock manifolds would be considered shorties i guess. thats why theres not much gain from going to aftermarket shorties, they flow a little better but its marginal. plus the 01-02 manfolds flow better then the 98-00 so you'd probably see a slight less gain with shorties then a 98-00 owner would.
if your on a budget you cant beat pacesetters LT's, coated there 339 from TSP. uncoated are cheaper but stick with the coated ones.
if you want full exhuast your gonna have to spend money, period. i got great deals on my setup and in totals from headers to catback and all the bolts, gaskets, o2 extensions it cost about 950 bucks and thats the cheap end.
if you get LT's you'll need a new Y-pipe. an ORY will run you from 120-200 bucks and a catted y is around 400-500 bucks. you can buy an ORY and have your own cats of choice welded in. or you can go a custom Y route, its the one i went. that'll run you about 150-200 bucks. i have a custom y w/ carsound cats.
also with LT's you'll need o2 extensions for the front o2 sensors and o2 sims for the rears or turn them off with ls1 edit or predatory.
a full exhuast isnt cheap but its worth it to me, the power increase and the sound validate it everytime i turn on the ignition .
Old Nov 9, 2003 | 09:10 PM
onebadz's Avatar
Defiantly go with LT's, more sound, more power, what more could you ask for. For more info check out the External engine forum.
Old Nov 10, 2003 | 03:19 AM
Jabroni's Avatar
Generally, a shorty header is better for power down low in the RPM ranges. The longer you go, the better the gains will be the higher you spin the engine. The Mac mid-lenghts aren't bad if you don't want to drop the coin for LT's. If you can get LT's, do it and don't look back. Someone already mentioned the way the car will sound when it's running. Soooo true. It's a wonderful sound compared to stock manifolds. Combine it with a sweet sounding cam...DAMN!
Old Nov 10, 2003 | 10:12 AM
samz28's Avatar
for the price the jet coated-type race longtubes from pacesetter are like $330. thats a great price. The ORY from pacesetter kinda sucks. It's pancaked on the top to fit i guess and has a shitty collector weld. I mean really shitty k-mart special y weld.
Old Nov 10, 2003 | 12:55 PM
z98's Avatar
z98
If you're really on a budget get the pacesetters and an electric cutout.
It'll be cheaper than getting a full exhaust and it'll outflow any catback too.
As an added bonus, it'll be quieter (although some people don't like that).
You can run with the cutout open, but that's too obnoxious for me.
There are plenty of options, but like onebadz said, try the external forum for more info.
Old Nov 10, 2003 | 04:20 PM
will magnaflow work the pacesetter LT's??, also what all does a CAT do??
Old Nov 10, 2003 | 06:05 PM
jrp's Avatar
jrp
SN95 Director
magnaflows will work with any LT combination. if you have to pass emissions at all the cats are a must, basicall they keep the pollutants from your car down. there are several high flow cats on the market to help reduce hp loss. also cats can be a way to keep rasp down with some exhaust setups.
Old Nov 12, 2003 | 07:56 PM
is there a difference in emissions between long and short headers?? i dont wanna have trouble passing emisssions...
Old Nov 12, 2003 | 08:18 PM
jrp's Avatar
jrp
SN95 Director
depends on how strict and what kinda tests you have. in cali we have emissions and my long tubes wont pass an official test . i have front cats and no rear cats but with a tune on a h/c car you should pass. with just LT's you should be able to pass the sniffer and OBD II test as long as you run o2 sims for the rear.
shorties will pass 100%, in realitiy only anything with a carb number is legal but **** that
Old Nov 13, 2003 | 03:26 AM
DALLAS's Avatar
I would go with the QTP's w/ the off road y-pipe and electric cutouts if I had the money. I cancelled my order the day before it shipped. I got caught contributing to a minor. Fines and lawyer fees $$$.
