bottom end question
Old Aug 14, 2009 | 12:26 PM
solo21's Avatar
Default bottom end question
I want to build my bottom end but dont know what I should look for as far as how much cc on pistons and stuff like that, I am running a d1 soon and want to make around 650 hp, I see alot of good deals on here but dont know if would work out for my setup.... example: there is a guy on here selling some Diamond 3.905 Pistons -2cc valve relief (.945 pin) And CAT H Beam Rods (6.098 945 pin....would this be a good set up for me? sorry for the stupid questions
Old Aug 14, 2009 | 12:46 PM
conan's Avatar
What heads are you going to run. You want the compression around 9.5:1.
Old Aug 14, 2009 | 01:23 PM
solo21's Avatar
im leaning towards some 317 heads....I have ls6 stage 2 heads now and are milled to 59 cc, i will keep it around 500 hp until I build the bottom end so im not to worried about changing my setup until I have the bottom built, but like I said I dont what Im suppose to look for exactly, I know about the brands but dont know what cc is going to get me where I want to be
Old Aug 14, 2009 | 02:07 PM
conan's Avatar
I have mahle forged pistons, they are flat tops with a -4cc. 317 heads that are 72cc, and .051 cometic head gaskets and that put me at 9.4:1 compression. So with your heads milled to 59cc I would look in to a new set of heads and keep the strength of a flat top piston. These should be 72cc heads... http://www.texas-speed.com/shop/item...d=133&catid=40
Also you probly want to get another cam, one with a 114 + lsa.
Old Aug 14, 2009 | 02:34 PM
solo21's Avatar
would it be a bad Idea to get my block machined to run those pistons and rods? Thanks CONAN for your help, you have helped me in the past and I really appreciate it! as far my heads and cam goes I know there not the perfect set up for forced air but I figured with me having a stock bottom end it might not be such a bad idea for my cam to bleed some boost, what do you think?
Old Aug 14, 2009 | 03:01 PM
conan's Avatar
So your planing on runing the blower on your engine as it is right now and building a new moter later?
If your going to reuse your block and crank with some forged rods/pistons I would give it the works... New main bearings (line honed) arp main studs. Have the cylinders honed, new cam bearing (installed by a machine shop) have the block decks checked, and have the rotating assembly ballanced.
Old Aug 14, 2009 | 03:11 PM
solo21's Avatar
ok.....the plan is to run the blower with my current setup until I had enough funds to build my block and then I run across this guy here that just might trade these pistons and rods for my NX system so thats why I got these questions now, lol....I wanted to see if I could save some cash with this deal here.....and didnt have a clue if it was a good deal for my current setup, and thats why I am here in the newbie section! lol
Old Aug 14, 2009 | 03:34 PM
conan's Avatar
Ok got ya. That size piston will require you hone the cylinder to its max. The rods I've never heard of. If it were me I would wait untill the engine is on a stand and some measurements are made before I bought pistons. You can sell your go gas kit, heads, and cam later for some cash to help off set the cost of the new build.
On a side note be very carefull running boost with that compression, Have a good fuel system and a even better tuner.
Old Aug 14, 2009 | 03:44 PM
solo21's Avatar
got it!!! thanks for everything! I hope I dont blow my **** up!
Old Aug 14, 2009 | 03:48 PM
conan's Avatar
Good luck to you. The forced induction world can be a big love-hate relationship!
Old Aug 14, 2009 | 05:25 PM
blue00ZZleeper's Avatar
x2 on that one lol
