Gear ratio and RPM's
I just got 3.73's installed in my car and the RPM's seem to be much higher than they should. I have an auto and at 50 I'm at 2000 rpm's and at 70 about 2800 rpm's. Does this seem correct? I reprogrammed the computer with my Hypertech programmer, but maybe I did something wrong?
That sounds like the mph for 4.10s lol? Are you sure you have 3.73s and didnt get 4.10s by accident or something ahaha.
http://www.f-body.org/gears/
Check there for what you should be at, although I have 3.42s and my speedo reads as I have 3.73s.. so im not sure how accurate that is either. In 6th gear at 80mph im at 2000rpms, I should be at 1800rpms
When your converter locks, your rpms will fall slightly but it will feel like the car is really responsive. Basically you can no longer slip the converter with it locked up. Normally unless its changed, your converter locks at 45mph.
^^^ thats true, you can count the gear changes. 1-2, 2-3, 3-4, 4-lockup with about a 400 rpm drop. Lock-up particularily happens when you reach good cruising speed and start lifting throttle to maintain speed.
Changing the tire height to 25.75 seemed to make a big difference. Now at 50 mph, I'm at about 1800 rpms. I also adjusted the shift points and that seemed to help it shift better.
^^If you have 30* of play due to lash then you are missin some teeth..lol
Put it on Jack Stands..mark the Drive Shaft where you can see it from where you spin the Tire. Start spinning and if the Mark comes around a little over 4 times then it's 4.10's.. if it came around roughly 3 3/4 times then it's 3.73's.
Internet Mechanic
I thought it was kinda funny.
