Long Tubes VS Shortys
#43
*just a thought keep the stock mufflers & buy the QTP Electric cut-out-Really trick & STEALTHLY! Remember "never lett'em see you coming"
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
i'm sold on those LT Pacesetters too-thanks
#48
LT's.
WHATEVER YOU DO, DO NOT GET THE FIRST GEN TSP ORY!
Unless you wan't the most horrible rasp you could imagine, coupled with the worst ground clearance possible.
I have to come to a complete stop for each speed bump in my complex.
I've heard the newer TSP Y is much better for clearance, and the merge is much nicer so it does not sound like donkey dick.
My TSP ORY is getting pretty much hacked up next week.
I'm only using a small section from it and putting in some 90* mandrel bends from jegs to make a custom Y that will go into an FM merge.
Then it will be to a POWERSTICK to replace the I-pipe then into a cutout.
Should sound sick.
But as it sits right now, I'm embarrassed to go WOT.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
-Matt
Should sound sick.
-Matt
