missfire at idle and white grayish smoke
I've noticed missfires at idle but no SES, and after a 150mph run at Wot, I saw a big plume of whitish, greyish smoke when I let off the gas which quicly dissapeared and I continued at 100mph for another 20 miles with no more excessive smoke.
Any ideas, are the two related????
Unit213 I can run it on an analyser, and no that was a NA run.
GOT ME SOM Besides coolant in oil, any other way to check for blown head gasket? Would that cause hickups and missfires at idle?
The light gray smoke only came on deceleration and for just a second then nothing.This was the first time it happened too.
Could this just be unburned fuel from a missfiring cylinder?
Bullit
Bullit
wrencher
Now after that the car is missing/rough at idle?
Does the car set a miss-fire code?
Check the plugs, & do a compression test.
If it blew a head gasket it would either be using antifreeze, or loosing compression in a cylinder or 2.
They usually make themselfs pretty obvious.
Worst case and I do have a blown gasket; what gasket would you recommend besides the stock carbon ones.
Also will the plugs show any tale tale signs (like color, smell, deposits) any pics??
And finaly, would white smoke show itself only at WOT or also at idle, upon start up?
