RPO Options.. help?
'Bird Director
From my 2000 Camaro/Firebird Service Manual....
FE4--Suspension System, Special Ride and Handling
K43--Generator, 102 Amp
N73--Wheel, Custom Sport Var4 17" (Restricted to Camaro SS)
QFK--Tire, All P275/40R17 BW
UZ7--Speaker System, 8 Quat Frt Dr Mtd Dual RR Hatch Amplifier
V12--Cooling System, Power Steering
'Bird Director
No problem glad I could help you....funny thing is I've got one on my car that the 2000 service manual doesn't even list....R9P. It's the only one I've not been able to find. I've even checked it multiple times just to see if I copied it incorrectly.....it's R9P alright!
Originally Posted by MasterEvilAce
I've found all of them except for these..
2001 SS
Thanks.
-- List revised
2001 SS
Thanks.
-- List revised
CAE - GM ST Therese to SLP LaSalle Quebec Four Upfitter Conversion
NF7 - Emission System Federal
PBT - Temporary Wheel & Tire for upfitter delivery
SLM - Stock Orders
TS9
Y2Y - Sales Package, Camaro SS Dual Label
1SD - Preferred Equipment Group
191 - Interior Trim, Ebony
192 - Black leather trim combination
6ZL
7ZL
71Q - Molding color red (doesn't make sense, maybe this is for SOM in '01?)
71U - Exterior color sunset metallic orange
8TJ - Component RR LH Computer Sel Susp
9TJ - Component RR RH Computer Sel Susp
Y2Y was easy, the rest came from firehawkowners.com, most of the RPO codes are interchangeable from GM vehicle to GM vehicle. The only thing I could come up with for TS9 was "CHMSL delete", which makes no sense unless you have no center high mounted brake light?
Excellent. Only 3 more left.
I also have two more questions.
1) I think I heard Sunset Orange Metallic w/ 6 speed is a bit rare.. anyone know about this? Is there a breakdown of all 4th gens anywhere?
2) Unrelated.. but What is up with this forum? When I highlight or click stuff, most of the text disappears.. and it takes a bit of messing around for it to come back.. Using Internet Explorer 6
This is as close as I can get to 6ZL and 7ZL.
My spec sheet says that 6ZR and 7ZR have to do with suspension parts, specifically:
6ZR- Component Frt. LH Computer Sel. Susp.
7ZR- Component Frt. RH Computer Sel. Susp.
Sorry I can't find anything on the last one but maybe these will get you closer to finishing the list.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
http://www.camaroz28.com/articles/01...rs/index.shtml
