Stupid Oil Questions
usually for winter storage I add 5 more lbs of air to the tires, put the battery on a tender, pack the tank with gas and add Stabil, and change the oil.Then just count the days down till spring
Any reason why I should fill the tank up with gas? I was thinking it would be smart to put just a few gallons in (with the right amount of Stabil) and in the spring I could top it off with fresh gas.
Packing the tank with gas will help to keep air out of the tank,the liquid inside will prevent any air that might have been there from rusting the tank walls.If it's a steel tank that is.
LS1Tech Administrator
Received 1,687 Likes
I normally keep the tank full as well. With the proper amount of Stabil the fuel will stay fresh until well past winter storage.
Does keeping the tank full help at all on a plastic tank car? Everyone always seems to say fill it up but I would rather put fresh gas in right after winter. I thought gas loses it's octane value over time, or does Stabil help with that too?
Stabil keeps fuel fresh, preventing aging and loss of octane. I normally use it year-round in my '98 car, as it only sees about 2-3 tanks of gas per year. This year I only drove the car 500 miles, last year was less than 200. Using Stabil, I've never had any noticeable octane loss or other fuel related issues with any car.
RPM WS6 You and I think alike. I like your warm up procedure. I tend to do similar.
Stabil will hold octane IF you put it in right when you fill up. You can't wait a month and then add it or you have already lost octane rating. Which now is making me think I need to drive my car to run some fuel out because it's been about a month since fill up and I never added any stabil.
Yes, agreed, that's a very good point that I forgot to mention. The fuel must be fresh, Stabil will not restore octane, only prevent it from being lost when added to fresh fuel.
