newbie stall question
Its not a better or worse thing, its just that the stall needs to match the rest of the setup including cam duration, head flow, vehicle weight, etc. You can cheat one way or the other depending on the intended use of the vehicle, but if you have a stock engine, a stock stall is fine.
A 3200 stall from a slow roll will still give you many of the benefits it gives you from launching from a stop. Also, an aftermarket stall will raise the shift extensions, which will keep you closer to peak hp during a run.
You need to define your car as in what it has for mods, what will it get in the near futures (1-3 years), and does any of those mods include Nitrous?? These can be big choices.
BUT in the spirit of this post I do have a suggestion. If staying N/A (no power added, cam at most) you would want a small diameter converter that stalls 4400 rpm, or in the converter world a N/A Converter. IF ricing from a roll is more your bag, then tone down the stall into the mid-3k from a good company.
BUT I also would not recommend top $$$ converters as in MOST cases, once the car is tuned, MOST tuners remove most if not ALL Torque Management, which means that transmission is suspect and can/will fail you at some point, especially if your making near 400 horse. So when the trans lets go, most time so much debris and shiz goes through the trans, it contaminates the converter.
4L60e's are junk, they do fail, and you want to be smart on your purchase. Yank, Circle D, Ultimate Converters, even Pro Torque or Percision Industries are great choices.
Look at either a stock dyno shee with either a LOW rpm pull on a chassis or even better a engine stand and you can see where bringing up the stall will help.
do you happen to know if tci is any good? thinking about possibly getting this one from ws6store.com http://www.ws6project.com/user_stor/...roducts_id=883
or maybe just a 3000 stall like this one http://www.ws6project.com/user_stor/...roducts_id=882 what do you think?
http://www.converter.cc/converters/street/GM/1/
YANK SUPER STOCK 3200 LS1
245mm, 3200 stall, 2.1 STR) The Yank Super Street 3200 is for enthusiasts running stock 3.15 gears, but want more "thrust" off the line. It bridges the gap between the Stealth 3000 and will hit the tires harder for excellent throttle response. $725
SUPER STOCK 3600 4L60E/4L65E LS1
245mm very high stall torque ratio. 3600 stall, 2.50 STR
Lightweight billet cover $725
http://www.performabuilt.com/converters.html#gm95 (9.5 inch non billet race converters
GM - TH350, 400, 2004R, 700R4, 4L60E*, 4L65E*, 4L70E* - $695.00 )
Basically your with in a couple of hundred from a proven TQ converter setup. TCI though "should" be fine, I personally never used them.
Although if roll racing is your big thing you would be wise to look into a manual trans. My stall helped a lot but I'm still slower from a roll than manuals with less power than me.
I used to have a friend, whom still post here and back in the day his car was a 2002 Camaro z28 m6 4.10's with Boltons and tune. MUCH lighter race weight then my 1994 Camaro z28 383 LT1 A4 3.23's 2800 stall. Now mind you, this was back before anyone heard of Lloyd Elliot and a lot of the stuff that makes LT1's fast were not avalible. Stall wall was still present on 94-95 ODBI Trans equipped Fbodies and I was still learning the trade back in 2002-2003.
But long story of the short, he ALWAYS like roll racing as he could not and to this day cannot race that car from a stop. Over powered for mods and under E.T. potential that car.
From a 20-30 roll I generally hold for about 1-2 seconds and he walk me, basically everytime. With exception of a miss shift and to me, I would not call that a victory for the me, just he let himself lose.
But get that same car from a dead stop and even with no suspension, 3.23 gears, Nittos, 2800ish stall (Pro Torque), and much higher race weight, I would put multiple car lengths on the car. My best ET back then was 12.08x @ 113 MPH and only did a 1.78x 60 foot and I think he was mid 12's on a good run. Eventually, and thats multiple tranny rebuilds later he did hit 11.9998 @ 118ish like once and I mean only once. He has since gone heads/cam/nitrous and bettered that but there goes to show the MPH diff.
MPH will tell you what the Weight to Horse power ratio is and that can basically guage how bad your going to get beat from a roll. HAD my 94 LT1 had a M6 with same gearing, I would prob MPH 115-116 and with control of the gear, the race would be decided on who got the jump and from a dig, who was the better raced (which is me lol).
Another perspective to consider.
If I had it to do over again I would do the PT4000 on the linked page instead of my SS3600. It is a VERY efficient convertor. BTW factory STR is 1.8
