2001 SS New headers Big Problems PLZ HELP!
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hello and thank you for your support! I recently bought a 2001 camaro ss 6 speed. About a month after I bought it I decided to put a new clutch and OBX Header/cat kit in it. The car used to run and sound great. Job done but with a couple issues. First off, the last exhaust manifold bolt back on the drivers side is snapped off flush in the head, which we did not fix....is causing an exhaust leak , but the bigger issue is that my car is not fast anymore! Louder but not as Fast anymore. Ive gotten several suggestions ranging from it being caused by the leak to me needing to reprogram the computer. The car was all stock and was very fast please share your thoughts on my problem and foolow up techniques to adding headers , hi flow cats and flowmaster muffler.I truly appreciate your help . Thanx!
If you can get at the bolt to drill a hole in it to insert an easy-out then you can remove the bolt without pulling the head. A 90* angle head drill works well in this situation since there usually isn't much room to get at it. Either a mail order computer tune or a local dyno tune is needed to adjust for the added flow of the headers.
Ya it does seem a bit worse. its so annoying as the rpms rise its a ticking type sound. also elsewhere alotta folks recommending a programmer or chip saying its mandatory with these mods?
it is really tight back there, you will have to take the header back off and might wanna take the air tube out too if you havent already because it will just be another thing to hold out of the way, then get at it with an easy out if you can
i had a similar issue when i did long tubes. the previous owner had broken off the very first bolt on the driver side.
i said f*ck in and still went thru with the installation. i couldnt fit any drill down there, so again i said f*ck it and put some RTV high temp sealent around the whole primary on the gasket.
6 months later and still no leak.
Bummer, then what happened to my car? it was just a swap. but it doesnt sound great or run great anymore wtf could it be. must be that leak idk. thanks 4 ur help n please stick with me on this
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Yes you can get the broken bolt out with head on (easy out w/right angle drill. No you do not need a tune but if you have never had one i would recommend it. And NO dont just throw some high temp rtv on and forget it, do it right.
