budget racing
Old Feb 9, 2011 | 06:34 PM
99ls1zam's Avatar
Default budget racing
With a 2,000$ budget .. what is the best bang for the buck after having slp lid , slp catback exhaust , and nitrous already on my automatic trans am? I have some thoughts but would like to know other peoples thoughts as well.. any opinions count. Thanks
Old Feb 9, 2011 | 06:37 PM
zaaronz's Avatar
If you dont already have one-- clearly a convertor next
Old Feb 9, 2011 | 06:39 PM
TankTheTurtle's Avatar
get a good stall and some DRs
Old Feb 9, 2011 | 06:46 PM
BStowers023's Avatar
agree^ Gears, Stall, Suspension and DRs
Old Feb 9, 2011 | 07:00 PM
99ls1zam's Avatar
What size stall recommended for a street/strip car? A friend of mine bought a stall and it made his camaro throw codes.. And what about the suspension.. what should i do?
Old Feb 9, 2011 | 07:01 PM
99ls1zam's Avatar
A tune after all that would be super high!!
Old Feb 9, 2011 | 07:06 PM
zracer323's Avatar
Stall, tranny cooler, headers and y-pipe and if you have money left then some drag radials.
Old Feb 9, 2011 | 07:38 PM
99ls1zam's Avatar
I deffinately plan on doing the headers and y pipe. But im kinda skeptical of the stall because i dont want to have to tune it just yet.
Old Feb 9, 2011 | 08:14 PM
zracer323's Avatar
You don't have to get a full tune. Around here, shops generally charge aroung $125/hr for dyno tuning. That would be plenty of time to tune for a stall, bump up the timing, and quickly mess with the fueling. Won't be completly optimal but would be enough for bolt-ons. A mail order tune would also be an option.
Old Feb 9, 2011 | 08:39 PM
99ls1zam's Avatar
I forgot all about the frost mail order tune. What size stall should i get? I was thinking maybe 373 gears not sure about stall tho
Old Feb 9, 2011 | 09:00 PM
Latch's Avatar
Drag radials before the stall of course, otherwise it's kind of a waste.
Old Feb 9, 2011 | 09:14 PM
99ls1zam's Avatar
I honestly think dr's will come last. My street tires i have now are hooking really really good!
Old Feb 9, 2011 | 10:11 PM
99ls1zam's Avatar
Enough about the dr's though. I need some opinions on stall/gearing size. 3.73's with 3200 stall .. would that be a good street-strip setup? Thats what a friend recommended to me. But then i had a friend recommend 3600 stall?? I have no previous experience due to always owning a manual. Any advise appreciated thanks guys!
Old Feb 9, 2011 | 11:06 PM
The Mighty Texan's Avatar
Came in to to suggest the spray but you got that! I dunno how the hell your street tires are hooking that good but as long as your happy! I would cam, if you look for a used one on here or one with the pushrods, rockers and all as a used set, get a frost tune ect, it will prob end up alot cheaper than you think maybe ~$600 even. I thought A4 guys always do the stall first, and yeah your tires may hook good now but im pretty sure if you get a good stall your gunna want some DR! Thats my humble opinion, good luck!
Old Feb 10, 2011 | 10:48 AM
99ls1zam's Avatar
Well i just put the nitrous on there last week. I havent sprayed it yet on the street tires so i guess it would be a good idea to get some dr's. Nobody will answer me about the stall so i guess im going with 3200
Old Feb 10, 2011 | 11:16 AM
Try searching, seems like there's got to be tons of info on different stalls since nearly every A4 gets one
Old Feb 10, 2011 | 11:23 AM
RobRomero's Avatar
Hope this helps
https://ls1tech.com/forums/automatic...et-driver.html
Old Feb 10, 2011 | 11:46 AM
Rauch's Avatar
You've got to look for yourself and decide what stalls best for your application and specs. There's no end-all stall that'll blow the rest away.
My only fear for you is hooking. You want drag radials. Oh, they'll hook great, but please don't tell me you have a stock rear. If so, maybe you'd want to spend that 2k into a stall/rear first. Might save you money down the road.
From what I've seen and read, since you've got an auto you'd be better aimed towards a 12-Bolt.
Old Feb 10, 2011 | 12:21 PM
99ls1zam's Avatar
Yeah thats what i was worried about. With this weather my work hours are terrible so i am on a huge budget at the moment until weather clears up some. My BIGGEST fear is being stuck at the track with a broke rear end. I hear they are junk in my car. But i think i am just going to have to wait it out because there is so many other things i WANT rather than need for my car. And the nitrous will not be sprayed off the line for that reason right there.
Old Feb 10, 2011 | 12:39 PM
99ls1zam's Avatar
Thanks for all the opinions guys! I am new to the race seen so any advise ya'll give me im learning. I do appreciate it!
