air/fuel ratio gauge
i just got a 2000 camaro with an ls1 swap and im tring to put in a air/fuel gauge and im not sure witch wire from the o2 sensor it needs to be connected to if someone could let me know i would really help thanks
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
There are "AFR gauges" that use the stock sensor and
give you a bar-graph LED display. These are "for
entertainment only". If it needs a LSU-4 sensor then it
will not be just a matter of vampire-taps to the wiring
harness and you'll have spent at least $200 for it.
You could hypothetically use a gauge on a narrowband sensor, and you could tune on one as well.
Is it worth it? Not really. Narrowbands are not very accurate. They Are only accurate at 14.7:1. Anything above and below I'd not accurate, hence the need for a wideband.
Here are many places that sell kits with the sensor, gauge, and perhaps other goodies.
-Derek
-Derek
No, you can use existing bungs or weld in new ones. You have spots for 4 O2 sensors, only 2 of which are needed, which leaves you with 2 extra spots to put a wideband in. Do NOT use a stock O2 sensor and wire a gauge to it. You would have better luck drawing a number out of a hat to get a AFR reading. You need a wideband sensor, which comes with a lamba controller to wire the gauge to. Gauge included, its about a $200 setup for the basic models.
Just bought the Camaro with Procharger, but previous owner tapped into stock O2's and gauge is all over the place, bouncing around driving me crazy. The QTP longtube headers don't seem to have extra Bungs so I'll get it welded in. Tks
