243 Head gaskets??
I Just pick up some 243 heads came off a 07 TB with 22k miles for my ls1. my question is i want to bump up compression. they are untouched heads. I will be doing a heads/cam swap but for now the cam will wait. so for now i want to swap the heads. im going to swap out the springs with some lunatti #73925K1LUN .660 lift so i dnt have to do it later while there on the engine, and there pretty cheap for the price. The cam i want to go with is a TSP 224r lsa 114. O also what push rods length will i need for now with my stock cam since they need to be changed? and after the cam swap?
So if you guys can help me out i would appreciate it thxs.
LS1Tech Premium Sponsor
If it's a standard bore LS1 short-block, then yes, 3.910" bore x .040" thick would work great!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If it were me, I would mill the heads and just use a GM MLS gasket. You can run a Cometic .040" gasket but they are about another $90 or so over the GM gaskets. Also, on the pushrods, it will just depend on how much you mill or what gasket you go with. Your best bet is to get a PR length checker and measure. This will ensure you get the right preload the first time. Let me know if you have any other questions!
Thanks!
Jon
Thanks!
Jon
yea i would like to mill them or even a port&polish, but this is my first build and would like to do somthing simple for now and building on a budget right now. But thxs Matt &Jon i really appreciate.
What do you recommend? im been reading alot on here and ive been hearing that comp 918 have been breaking a now pac springs have been breaking also. the reason i wannted to go with lunatti was because havent heard any bad things about them and i thought the extra lift wouldnt stress out the spings at high rpms.
