Cheap/Best Super or turbo.
Neither of these is done for cheap, if it is pieced together, intalled and tuned correctly. You are talking about 6+ Thousand dollars for either setup....because you will need a new rear-end and suspension to handle the power.
READ MY SIGNATURE
READ MY SIGNATURE
There are a few deals out there. My buddy just sold his sts rear mount system with upgraded turbo for about $900, just needed some wiring and oil pump. I really wanted to get it but didn't have the money at the time. Could have bought it, done injectors and ran low boost and got a dyno tune and have been set. IMO i think it can be cheap if you run really low boost but when all you guys start talking about 900+hp set ups and stuff I know that can get unreal.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
im thinkin he just wants some simple turbo he could add without breakin the bank and nothing that required a bunch of extra supporting parts or labor.
as you know...you get what you pay for but here is a cheapest basic starter turbo kit that has an i/c.
http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
cheap as in 500 bucks. or something like that. just a slight increase in power.
If you want to be quick, and you want to do it cheap... and like you said, your not that mechanically inclined. Just do a gear swap (3.73 auto / 4.10 manual), suspension, headers back, some tire, maybe a small cam & ls6 intake. That'll more then take care of the majority of cars out there, be a ton of fun, with no real upkeep.
Once you get into FI, it becomes a lot of work... and things start breaking. You almost have to have a 2nd car just incase.
and since i have this SS i already have the Ls6 intake.
I believe the car might already have tighter springs, SLP exhaust as well.
so basically all i need is the 3.73 gear, cam, and better tires.
i run Nexen NS3000 17(front) 18 (Back) currently
yeah ive been thinking about a small cam.
the ls6 is because its a 2001 not because its an ss, all 2001 and up are ls6.
-matt
XD yeeeaahh, um i realize this car isnt as low class as my old one, there are no 500 buck FI kits that are good.
Sorry guys ive been on FBO ever since i made this account XD..well its camarozone now
but yeah this thread will be left alone for a while, i havent decided on a turbo system yet.
but i dont have cash for a good one. I want to go twin turbo though
#33
if u have the fab skills and knowledge u can do a custom rear mount kit for around $1k-1.5k depending on what deals and parts u go with, im currently finishing my rear mount now and only spent $1200, no tune yet or injectors but its not finished ether so im estimating about $2k give or take after injectors meth and tune, but u can go cheap ISH with turbo, but i did double what i planned on spending almost instantly : \ and im only 1/3 the way done with how i really want this kit too be, but its a slow build as i want it to be and im only on my "stage 1" of 3 im doing for this kit
#35
yeah, now im just wondering what would be a good name to buy.
There is a kit advertized on this site that retains the A/c and mounts the turbos on the side of the motor.
But i cant remember what its called. Someone has been developing it for about 2.5 yrs.....
#40
wow, almost 95% of people in here dont even own a car with forced induction. Here's some real world input: I own a turbo car and have driven MANY supercharged cars (supercharged: vette's, 5th gen camaro, mustang, bmw M3, f150, monte carlo, impala, etc)
My car has had: stock LS1 w/ cheap ebay turbo kit & ebay turbo (I helped design [aka fix the problems] the kit for one of the chinese companies), 404ci w/ ebay kit & ebay turbo, 404ci w/ custom turbo kit & ebay turbo, 404ci w/ custom kit & turbonetics 76mm, 408ci with 91mm T4 turbo, and will be switching to a 91mm t6 turbo soon.
My car currently has 850+rwhp, so I have had some extensive experience with forced induction systems
For someone with limited mechanical skill, and limited maintenance capabilities, go with a supercharger on LOW boost, on the stock engine.
I would still recommend having a second vehicle. My car would still have bolt ons if i didnt have another car to use.
if you have a high level of skill, craftsmanship, and time, you can build a turbo system yourself that has much greater potential than a supercharger.
you can run on the factory drivetrain if you know how to drive. I daily drove my car with 773rwtq with the stock rear-end for over a year. yes it eventually brock, but on lower power, it can be done.
you will however spend $4,000 to $5,000 NO MATTER HOW CHEAP YOU MAKE IT
you need the supercharger/turbo, fuel system upgrades, clutch/tq convertor upgrade, install fees, professional dyno tune, and unless your car is in 100% working order, little things will start to die and break, guaranteed.
Turbo: Thats not even close to being true. If you spec out a good combination it will spool VERY quickly. I had a 76mm on a 404ci that would have full spool by 2k rpms.
Supercharger: Yes you have instant boost (which is harder on the drivetrain) but superchargers tend to drop power in the higher rpm range due to heat soak and increasing parasitic losses
i have a 91mm turbo. it spools much quicker than that.
Hhaha I agree!
Hhaha I agree!
