Stall with stock rear-end
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I was looking into stalls for my 98 Trans Am a4 with 89k miles. Ive heard that with a good stall and DRs you are putting alot of stress on the rear-end. I know im not going to be getting a new rear-end anytime soon with my financial situation so which stall would be the best for my rear-end..
I put a yank 3600 with 85k on stock rear. I guess if your really that worried go with a 3000-3200. If I were you i would go higher because it seems nearly everyone is dissatisfied when they go low or even consider putting the money some where else like headers ect.
I went with the yank ss3600 stall, and a agressive lsa cam...as long as your not hammering on it all the time u should be good! I rommp and roast all the time, mine stock rear is holdin up!
Yes this is all I had on my stock rearend also exept the moser 3.73 gears and I had a 4000ss yank in mine. I never got under a 1.6 60' though and I just had bolt-ons. Best runs was back to back 12.10@111mph. Using 255/50/16 Mickey Thompsons on the stock rims I had literaly 100's of passes on that.
Saw a video on youtube of a guy with a 100% Stock LS1 (except for drag radials+4000 Stall) And he got the car to life the front end a couple inches haha, He also said he broke 2 10 bolts in a week.
I had a 2200 'street stall' by precision industries and broke the axle tube casing off the rear end inside 3 weeks. Looked like a grenade was tossed in it when it let go.
Bottom line is the rear is a weak link... It will either handle it or it won't and there is t really a safe sized stall to go with. Get what you want and if the rear goes consider it a sign that you need something better than a 10 bolt.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Do NOT go less then a 3500 stall. You will regret it if you do. I ran a TCI 3500 for three years with a stock rearend and 3.23's. I had at least 200 track passes with 1.6-1.7 60's. The key is to always preload the drivetrain before you launch. I liked to brake stall up to 2K and then let her rip ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
As for the stall brand, I would go with either Yank or Circle-D. They are both top quality converters.
LS1Tech Administrator
Received 1,703 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I would not worry too much about the stock 10 bolt in an A4 car at stockish power levels, even with a stall. If you can prevent wheel hop, then you should be fine for quite a while.
But keep in mind, racing breaks parts, so nothing will last forever.
