Porting a Throttle Body!!!!!!
- If you have access to a die grinder, use that for the porting instead of a Dremel. It will go much faster!
- Remove the IAC valve, coat a AA (I think that will fit) battery with Vaseline or something similar, then insert it into the IAC bore so it blocks off the hole and won't let epoxy get in there.
- Use an epoxy that's thick so it doesn't run all over the place while you are waiting for it to set up. After I did mine, I found some stick epoxies that you knead until they are ready then you just stick them in place and let them set up. Those might work well, I haven't tried them though.
- Make 100% absolutely positive that you remove any and all traces of epoxy from the IAC bore. My car wouldn't idle right at first and I had to go back and clean the area up. For this I used a dental scraper and an Xacto file set.
- I rounded off the edges of the holes that I drilled into the epoxy to reduce the whistling sound I was getting at around 2800-3000 RPM. Think of blowing across the top of a beer bottle to make it whistle. It was the same type of noise just VERY high-pitched since the holes are so small in the TB. The same Xacto file set worked great for this!
So did you get any SOTP gains, and how long did the process take you (not counting the second go around/cleaning IAC bore)?
If I were to do it again: porting time < 15 minutes with a die grinder; epoxy < 10 minutes with the stick stuff; drill and shape holes ~15 minutes still. About an hour total including removal and re-install of the TB, but that takes into account that I did the TB bypass mod at the same time and don't have to fool with the coolant lines now.
