head selection help
Old Apr 9, 2012 | 05:15 PM
ron6.0's Avatar
Default head selection help
Alright guys, i am building a lq4 6.0 stock bottom end, carbed top end. Its going in an 87 s10 street/strip. My question is should i buy gm stock l92 heads with valve spring upgrade or spend a little more money and get the tsp 5.3 cnc 2.5 heads?
Old Apr 10, 2012 | 09:30 AM
SOMbitch's Avatar
Stock L92 heads are better by a wide margin. The big thing is they are very finicky about cam choice so contact Pat G on here or call Geoff at EPS or Ed Curtis at Flowtech Induction and get a custon speced. Best $25 you'll ever spend.
Old Apr 16, 2012 | 02:07 PM
ron6.0's Avatar
Any more opinoins before i buy the l92 heads?
Old Apr 16, 2012 | 04:29 PM
2000PewterT/A's Avatar
Agreed 100%, the L92 heads are great, they just are very picky to which cam they like to perform with.
Old Apr 16, 2012 | 09:51 PM
garygnu's Avatar
which head will best line up with the intake you plan to use ?do you plan on using stock gm rockers ?
Old Apr 16, 2012 | 11:17 PM
SOMbitch's Avatar
Maybe my bad but I assumed he already knew about about the intake and offset rocker differences????
Old Apr 17, 2012 | 07:01 AM
ron6.0's Avatar
I plan on buying the offset intake rockers and new stand. I want to stay with gm stock type rockers and i also am tossing between the gmpp l92 single plane and the l92 vic jr.
Old Apr 17, 2012 | 07:03 AM
ron6.0's Avatar
The main reason i'm torn betwwen the two is my friend has the texas speed heads and they perform great, but i hear nothing but good things about the l92 heads
Old Apr 17, 2012 | 07:17 AM
bww3588's Avatar
The l92's are cheap and perform just as well as some heads that cost hundreds if not a grand more...in stock form. There is plenty of room to grow with them.
But like mentioned, they are picky about cams.
Old Apr 17, 2012 | 07:19 AM
bww3588's Avatar
The only downfall I can see is you are going to want an aftermarket piston with valve reliefs. The 2.16 intake valve does not leave room for much of a cam.
Old Apr 19, 2012 | 06:56 AM
ron6.0's Avatar
Thanks guys, i will get them ordered!!
