I think I have a freak...
LOL!!! I did that when my car was a V6, and I actually calculated a consistent 1-2mpg increase after it (if the "tornado" that you're talking about is what I'm thinking). Buttt it was probably due to the MAF reading better or better maintenance of it. Now with the V8, I'm just like "Lolz"
to the OP May some unseen dirt on the road, every time and every where you drive? Or it's the placebo effect? Or an angel has touched your car. Whatever it is, enjoy! Just...good luck with the rear
LS1Tech Administrator
Received 1,803 Likes
If you want it to look as correct as possibile while still being able to use the better aftermarket lid, you could get a factory ram air decal and put that on the aftermarket lid. I've seen many people do that over the years, and I always intended to do that with my WS6 but just never got around to it.
The part number for the decal is 12455211, and I just ran that number through GMPD and it appears to still be active. List price is $33.74 but GM Parts Direct sells it for $20.51.
Hope that helps.
LOL!
Hope that helps.
Hope that helps.
Edit: Ok so after a day of driving with the MTI lid on instead of the stock WS6 lid I will have to say that I'm pretty sure I felt a difference. I'm not saying that the car is now a 10 second, fire breathing drag strip terror but I'm convinced it made a difference. I also know this is a ricer thing to say but I really like the look of the stock WS6 lid, and I wish the MTI could look as good. Question: why does the stock WS6 lid have two parts: the lid and then the E-shaped assembly behind it, and why don't aftermarket lids like the MTI have this E-shaped assembly?
What you are talking about is called the baffles. I believe baffles make the car quieter but do nothing for performance so all the aftermarket lids don't have them.
Lids have been proven for years to gain 7-13rwhp on average on stock engine applications, so it's not going to be a huge difference by itself, and certainly won't transform a car into a monster version of it's former self. Did you change the air filter at the same time? Maybe the old one was clogged. Maybe some cooler weather is also making the car feel faster and making traction worse.
Edit: Its also well known that the SLP baffle is an appearance mod.
As far as appearance, I personally like how the engine bay looks a lot better without the clutter of the silencer, so I have never missed it. But of course this is just an opinion thing....although I guess it does count as weight reduction as well.
That "E" shaped thing is an air silencer, designed to reduce intake noise as mentioned above. Removing that silencer is one of the reasons why you gain power with an aftermarket lid. The other reasons are the elimination of the ridges on the underside of the lid, and the round collar that connects to the MAF (rather than the oval-to-round merge of the stock lid). So in summary, adding a silencer to the aftermarket lid would negate much of the potential gains of the aftermarket lid.
Another question: should I switch back to the standard, shorter T/A lower air box, or keep the taller WS6 lower air box? I can't imagine it makes a lick of difference but it couldn't hurt to ask.
-And to think I almost threw that MTI lid and lower air box in the garbage, too...
Good thing you kept the MTI lid though.
