what plug gap to run?
Old 08-08-2012, 05:53 PM
tamark's Avatar
Default what plug gap to run?
just got an 01 trans am pretty stock motor, headers, no cat, 3 inch exhaust noticed the plugs were ngk tr6 one step colder then stock gapped at .035 guy told me motor was tuned by owner before him,should i put in tr55 plugs n gap at.060?motor runs ok just seems like it should have more.
Old 08-08-2012, 07:01 PM
00ZNewb's Avatar
Tr6 gapped at .35 sounds like it might have been tuned for nitrous. which would explain it being sluggish without it.
Old 08-08-2012, 07:56 PM
sepsis's Avatar
I had NGK TR5's gapped at .043 in my car and after a while it began to misfire at high rpm's. I switched to the Autolite Copper plugs gapped to .040 and it runs awesome now.
Old 08-08-2012, 09:30 PM
tamark's Avatar
ok i may try those plugs, i was thinkin maybe nos was used, u think a hotter plug would be good?
Old 08-08-2012, 09:46 PM
sepsis's Avatar
For a mostly stock motor, I would stick with a stock spec plug.
Mine has pretty much the same mods as yours. Headers, ORY and a Hooker Aerochamber, P&P TB, a tune and a lid. The stock type plugs seem to work very well.
Old 08-08-2012, 10:05 PM
TransAmWS.6's Avatar
True, no need for a different heat range than stock on a stock car. Seems like anything between .050"-.060" should work good. The TR55's I have in my car are gapped at .060" and there was a huge difference that was felt between these and my clapped out stock plugs.
Old 08-09-2012, 11:01 AM
mjs1012's Avatar
tr55's are good for your car. just gap them around .55 and youll be good to go.
Old 08-09-2012, 11:12 AM
BriancWS6's Avatar
I'm not trying to come off as an ***, but do a search. I have explained this very topic multiple times myself, even very recently. You'll find some great info if you look for it.
Good luck.
Old 08-09-2012, 11:19 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
TR55's gapped .050-.055" will be great!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: what plug gap to run?
