Matching cam to factory heads
I have been reading alot about cam selection in our forums as well as my LS1 build book that was published in 2003, but have not found the answer that I'm looking for.
I have a 2000 Camaro SS 6 speed car. I have a ported and polished throttle body and an SLP air box lid. This winter, I plan to install a set of long tube headers, 4.10 gears, and a cam (along with valve springs).
Taking the heads off is not in the cards for me. I only put about 1k miles on it per year. the car goes out on date night and to cruise nights.
I want a cam that makes good power down low and mid range. For cruising around car shows, I would really like to have a tough sounding idle.
I was hot for the GMPP HOTCAM, but was not sure if there was another cam that someone has experience with that may be a better performer with the factory heads and piston valve reliefs. Any help or guidence would be much appreciated.![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
OP asked the right question and gathering important info to make an informed decision, this is cool. Hope you find the right cam! ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
However , do stock transmissions with a stronger cam make a difference between an A4 or M6? I am assuming a different cam be recommended with the six speed due to an absence of a torque converter.
go to ls1howto.com for pics and instructions.you won't have any problems with the valve covers.you will 2 5/16 dia steel or wooden rods for holding up the lifters.the hardest part is installing the balancer bolt.I agree ,the tsp 228r cam pkg would work great in your car.
WOW, I can't believe how helpful everyone has been. And there wasn't any cyber-fighting over differences in opinions. I was once a member of a Subaru Impreza forum that had a very different culture. I LIKE THIS!!! I will continue to read on this subject while saving my $moola$. I am leaning towards the TSP 224/228 WITH 111 LSA. I'll probably get their install kit that comes with springs and push rods and am up in the air on the tune. Texas Speed does a mail in tune, but I've also read good things about Frost.
Any thoughts on having the cam grinder tune the computer or sending the cam to Frost.
Well it always helps when you're given some good useable information, I based the cams I chose off of what I highlighted above. I would still recommend you find a good tuner in your area over a mail order tune. IMO, nothing beats having a tuner be able see/hear/smell/feel the results of the adjustments right then, and if it's not the right one then He can make adjustments right then on the spot.
Thanks for the props. I know that to be happy with my final product, I need a plan.
I will start a new thread when I begin the project.
I did some asking around and found that a good friend of my old man has been working at KC Engines. The have a chassis dyno and I hear that they do a lot of work on LS motors.
Have any of you in the Kansas City area done any work with them?
www.kcengines.com
www.kcengines.com
I am running the Lingenfelter gt1 cam (.218,.229 .563,.563 on 113 lsa) with stock yellow springs (which Lingenfelter recommends) ls6 intake and longtubes and put down 404 rwhp. It has awesome all around power and nice choppy idle. Sure I could have went bigger....sometimes bigger is not always better.
Posted from LS1Tech.com App for Android
#32
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Stock heads don't respond much to higher lifts. If you're
committed to staying with the 241s, then don't bother
with a high lift cam. I've seen some charts of flow vs lift
somewhere around here, for various heads. Probably buried
in the Internal Engine section, a year or three deep.
#33
Alright, I'm back on this post. I ported and polished my own throttle body and got the SLP lid. I decided to go with the BBK long tube heads, not the stainless steel headers that I was originally aiming for. They are sitting in my garage with the y-pipe. So.... I am soon to have the headers and no cats! Hopefully my wife or parents decide that the Motion 4.10 gears are a great gift for their loving son. Ha Ha, no really! I plan on getting some Poly motor mounts to install while I'm doing the headers. I need to post a couple pictures of my car because it is beautiful!!! It was purchased new by my Mother in 2000, and I've been staring at the beauty since then. She got tennis elbow and couldn't drive it anymore. That's when I acquired it. I used to want to keep it all stock, but that hard for someone with HOTRODDING in the blood to do, so here we go. I am going to approach my friends at KC Engines about some possible head work on my 241's. But, I still have a hard on for the Texas Speed 224/228 cam with 111 or 112 LSA. If someone thinks there is a better cam selection for the factory 241 reworked heads, let me know. Remember, I don't want to spin my mill over 6k. Is everyone still happy with my combo? by the way, I am going to keep my factory SLP duel duel exhaust. Thanks again for all the input.
#34
I still think you'll be happy with your choices.
FYI, just keep in mind that the cam, headers, and ORY-pipe will make the exhaust system smell and louder. So, if you think the exhaust smell is going to be an issue you'll want to either add a catalytic converter/s or go with a smaller cam.
#35
#36
#37
#39
You could always talk to Maxx Mitchell (ls1tech unsername) or Justune (I think he tunes for MC Racing). They do alot of the tuning in the KC area and have tuned some really high horsepowered ls cars.
#40
well I went with an off the shelf TSP 228R with 112 LSA. Installing comps rocker trunion bearing kit, bee hive springs, self ported oil pump, and a mail order frost tune. I hope to fire it up memorial day. Thanks again for everyones input and advise.
