ls1 or lq4
[QUOTE]Originally Posted by Badls6SS
408 = 495rwhp and 470 rwtq.
eagle crank and h beam rods
diamond -2cc pistons
GMPP cnc ls6 heads 64cc
cometic .051" gasket
Fast 90mm w/ NW 90 tb
cam motion 244/249 641/644 112lsa
85mm maf
38.5 inj.
walbro intank pump
meizier elec. pump
1/34 stepped to 17/8 dyna tech headers into 3.5 stainless works exhaust
M6 w/ moser 12 bolt and 4.10's
i think this is the set up im going to be going with. Atleast until i can get a good set of ls3 heads and a ls3 intake i think its some pretty good number
85mm maf
38.5 inj.
walbro intank pump
meizier elec. pump
I think the lq4/9 block will suit your needs easier than the ls1.Both can give you the power you want for sure..there are pros and cons to each.I feel the ls1 cons taking it that high n/a arent worth it.The lq blocks even as a 402 are very strong..tq comes on earlier and lasts longs in the band.You can build this over time..get the block and stroke it out.Then slowly swap out parts on the topend as you can afford them...nothing but gains this way..plus you get more used to the car as its power grows so will you.I dont recommend building this all one shot if you never had a car with over 400whp as raw as a built motor lol.Sometimes its best o earn your stripes..wanting a dyno queen car and being able to dive said car are are extremely different things!
yeah you make a very good point. Ill just stoke it and use all the parts i have now and slowly build it so i can get used to it and not eventually wrap myself around a poll lol. Thanks for all the info you have been very helpful.
No problem,just trying to give you options without breaking the bank.Start off with the lq4 and swap all the ls1 stuff onto it.Then get full exhaust...decent cam,ls6 intake and you are already close to 400whp.Thats where Im at right now...next for me is 243 heads and might go bigger of a cam.Great daily driver...still get good gas mileage till i romp on it lol.Im still highly thinking of just adding boost to the motor as it sits now would be an easy jump in power for a few extra bucks.
