A few Newbie questions that need answered please!!!
I just bought a 95 Silverado with a 2000 ls1 out of a 2000 corvette! I have a few questions after looking under the hood.
First, there's a brass fitting at the front of the intake manifold (driverside) right behind the tb.. What attaches there? It's some kind of vacuum I'm guessing
Second, there's a plastic tube coming out of the back of the driver side valve cover and its broken after about 3 inches.. Idk what it is or where it goes
And lastly, the o2 sensors aren't hooked up, I found the plug from the harness on each side, but idk if they are front or rear. They are square femails with 4 male pins inside, the wires are purple, pink, tan, and black?
And just curious, my maf is unplugged as well as the o2's being disconnected.. Is this bad? The other day at idle I plugged the maf in and it started to kill the engine before I unplugged it again.. Idk I don't know fuel injected very well. Just carbed engines really..
The brass fitting goes to the evaporation soleinoid which appears to be missing. That is A decent vacuum leak.
The plastic fitting goes to the pcv system. Hook it up with the line running to your pcv valve. The pcv valve is directly below your throttle cable in the last pic.
For the evaporation fitting, just cap it off if you don't have the equipment.
After that, hook up your o2's and maf and see how it runs. More than likely, someone unhooked the maf and o2's to force it into open loop to overcome the vacuum leak.
I believe so. But it's gonna cost you. You can easily piece it together with some 3/8 fuel line, a t fitting and some hose clamps. Just make sure you route everything correctly. Connect both rear valve cover nipples to either end of the t fitting and run a line from the t fitting to the intake where the pcv valve is. Then connect the passengers side front valve cover nipple to the fresh air fitting on the throttle body.
Just cap the evap nipple on the intake unless you still have the evap system on the truck.
That IAT might be like that because if that corvette motor is using the 5 pin MAF the IAT is integrated in the mass air flow housing. Count the wires on the connector. That might be left over from the truck harness or something. If not you can easily just put a grommet in the piping and install it.
If you want to redo your pcv hoses I helped a guy with it in another thread and it has the correct part number for the pcv valve and some pictures here:
https://ls1tech.com/forums/generatio...over-hose.html
Thanks everyone for the quick and accurate responses! Can anyone point me towards where in the harness I might find the plugs for the front o2 sensors? I found the rears, unfortunately it's the fronts I need
There should be plugs for both the front and rear o2's. 4 total. If you can only find 2, someone may have pulled the rears from the harness and you may only have the fronts. Which is fine. Peel back the loom and look at the wire colors and match that to a wiring diagram for the Corvette and see which they are
Your pcv routing is fine. Now get your o2's figured out, plug that maf and ait sensor in and let's see if this thing runs.
