Inlet diameter LS6 intake manifold.
What is the inlet diameter size on a LS6 intake manifold? will a fast 92mm throttle body fit on the LS6 intake? how much power is a LS6 intake good for?
LS1Tech Premium Sponsor
It's about 78-80mm. Most any of the aftermarket 90 and 92mm TB's will be the 4-bolt pattern, whereas yours is the older 3-bolt pattern for mounting. I'd either have the stock TB ported, or save my money and get into the FAST 92mm intake and TB when I could.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Well this build question is regards to my cousins trans am. He bought a FAST 102 intake and 92mm TB. But his trans am aready has a LS6 intake so I was thinking since the LS6 manifold is good for 400+hp. Just swap out the TB on the LS6 and call it good, and sell the fast intake and get headers and exhaust since hes on a budget build. He plans on eventually doing cAm swap later. What do yall think???
You will see little to no gains from a 92mm tb on an ls6 intake, you might even see a loss. The intake will only flow what it can, increasing tb size on an intake that is typically maxed out on a small cam, mild heads 346 is not going to make it flow any more.
If your going to sell the 102 intake, sell the tb with it. It's pointless.
