to diy or not to diy......h/c install
Well I'm at a crossroad. I've had the SS for spittle over a year now and have most of the major bolt one done...but I want/need more power and a choppy idle. (Crazy right?) I have done things right with this car and refuse to go the cheap route as far as parts but will save every dollar I can installing things myself. I am good with mechanical stuff and have almost every tool known to man at my disposal (except a lift). But I am weary of engine stuff due to the risk of having the damn thing explode on start up (yes I know not likely if I follow directions via ls1tech). Basically I want to hear it from someone who was sceptical of doing a h/c swap and then did it. Talk me into it. It will be my project over winter and will take my time to make sure its right. I just need a brave heart speech from ls1tech to push me further. Prepare me for battle.....
As of now this is how the car sits.....
Slp tuned length Lt headers
Ory
Magnaflow CB
Ls6 intake
New plugs/wires
25% ud pulley
Air/egr!
Umi rear controll arms
Umi sway bars
Umi on-car adjustable panhard bar
Hotchkis struts tower brace
Bilstien hd's
Dyno tune
Made 33(x)hp/34(x)tq
I have done more but the rest is cosmetic and comfort stuff.
What Im thinking for a set up...
Texas speed package 5.3l heads and whatever springs they recomend
228r cam
Pushrods
Ls7 lifters
Ls2 lifter trays
C5r timing chain
Texas speed oil pump
Texas speed gasket kit
And p&p my throttle body
Rocker truision upgrade
Dyno tune
I might be missing some stuff so fill me in...
Looking for 400+HP/tq
Ory
Magnaflow CB
Ls6 intake
New plugs/wires
25% ud pulley
Air/egr!
Umi sway bars
Bilstien hd's
Dyno tune
228r cam
Pushrods
Ls7 lifters
Ls2 lifter trays
C5r timing chain
Dyno tune
LS1Tech Premium Sponsor
Seems as your list is pretty complete. I vote for the DIY route as I find it is very satisfying when you have put something together with your own hands. Heads and cam are time consuming, but after one install yourself, you will be glad you did it and saved yourself the $.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
This is what I am talking about. But I do want to do it. I think when the real cold weather gets here and it snows I'll want something to do so why not.
Go for it, take your time and read up as much as you can before attempting it. I am always an advocate for people doing the work themselves because it feels 100 times more gratifying when you drive it knowing you did all the work.
When I did H/C on my Camaro it was the first time ever doing it on any vehicle, and I did it all by myself; IMO do it yourself ! I'd also make sure you have all the fasteners, torque specs, and tightening sequences, and plenty of time before starting.
BTW, use a shopvac with a washable wet/dry filter after you remove the water pump to get most of the coolant out of the block and heads, it'll reduce your cleanup time after removing the heads.
just take your time and double check everything. Make sure you install the cam dot to dot and also have a good calibrated torque wrench. Make sure you torque the rocker bolts properly. You CAN snap those bolts easily. Also stuff rags in the oil pan before you remove the oil pan pickup bolt. It will save you a headache.
This I have been doing as well as trying to find out which can i will be happy with. I was at first thinking ms3 and but think with the mods I have now (mainly the slip tuned length lts) that it probably be better to keep my curve lower in the Rpm range.
This has probably already been mentioned, but LS1howto.com has a pretty good step-by-step for this.
__________________
I will be honest, I was a skeptic before my first install as well, but if you take your time and do your homework before hand, you will find its not too bad!
__________________
I pulled my engine/trans and did a LQ4 swap by using a write-up on this site. I quadruple checked every bolt I tightened down when I was putting it back together just to have the ease of mind. I vote DIY, after everything is done and you start it up for the first time the feeling you get is AWESOME!!!!
